Pocket GPS World :: View topic - Can't Sync
Can't Sync
Solly
PostPosted: Thu Sep 23, 2004 9:06 pm    Post subject: Can't Sync Reply with quote
Sad
Its a few weeks now that I can sync my PDA to POI warner.
Here is the error mssg that I get:
"23.09.04 20:48:12: Start Synchonisation...
Server Error while processing Overlay: Uk Defe
23.09.04 20:50:01 Connection closed
Any assistance will be appreciated.
Beefy
PostPosted: Thu Sep 23, 2004 9:26 pm    Post subject: Reply with quote
Solly,
In the "POI-Sync" => "POI-Selection" => "Extras" => "Settings", have you the correct login information?
This sounds as if this information has been changed or corrupted.
Beefy
High Quality Pubs - http://www.pocketgpspoi.com/reviews/tomtompoi/High_Quality_Pubs.zip
TomTom ONE
Solly
PostPosted: Thu Sep 23, 2004 9:54 pm    Post subject: Reply with quote
Beefy,
I just checked and double checked and my username/login is correct is correct.
any more tips????
Beefy
PostPosted: Thu Sep 23, 2004 10:02 pm    Post subject: Reply with quote
Sorry, but have you ever been able to sync this POI? And how many POI's are you trying to Sync?
Have you checked that the POI still exists on the server that you are trying to sync with?
If it is still there then I would would suggest contacting Markus by email and see if he can help.
My instinct is to de-install and re-install, although this didn't work for me very well so I had to do a Hard Reset and reloaded everything.
Beefy
TomTom ONE
Solly
PostPosted: Thu Sep 23, 2004 10:07 pm    Post subject: Reply with quote
I have been able to do several synchs and did for a few weeks. When it failed the first time I thought it was the Server as the error indicated. I will have to try a hard reset.
BTW who is Markus? I am using a medion with navigon
Beefy
PostPosted: Thu Sep 23, 2004 10:11 pm    Post subject: Reply with quote
Markus Schwarzkopf is the author of POI-Warner. You can contact him on: info@navigating.de, he may take a day or so to answer your email.
Beefy
TomTom ONE
Solly
PostPosted: Thu Sep 23, 2004 10:19 pm    Post subject: Reply with quote
Thanks mate,
I have just emailed him and will await a response before a hard reset
Thanks again
Solly
PostPosted: Tue Sep 28, 2004 8:32 pm    Post subject: Reply with quote
Can anyone out there help me please. I have sent Markus an email but has not received any response :x
I still can't sync........I have removed the programme and re-installed it. Same problem.
Any help would be appreciated.
PostPosted: Tue Sep 28, 2004 9:24 pm    Post subject: Reply with quote
I don't use POI-Sync but have you installed any firewall software on your PC? ZoneAlarm, Norton Internet Security, WinXP SP2?
Solly
PostPosted: Tue Sep 28, 2004 10:17 pm    Post subject: Reply with quote
I have no firewall and have checked and found XP's own firewall is not enabled. I should let you know I used to be able to syn before and it has just stopped over the past 3 weeks.
PostPosted: Wed Sep 29, 2004 7:38 am    Post subject: Reply with quote
Darren, it's not POI-Sync he's using, but POI-Warner's own sync service.
It could be a number of things down to IP block, corrupted POI. You may find it best to delete all POI's on your PPC and re-sync from scratch.
Solly
PostPosted: Wed Sep 29, 2004 9:30 am    Post subject: Reply with quote
I have manually deleted all the POIs via the file explorer on the PPC and tried to re-sycn. Still same problem.
What beats me is that it used to work flawlessly until a few weeks ago.
PostPosted: Wed Sep 29, 2004 11:04 am    Post subject: Reply with quote
I think your best bet will be to wait until you get a response back from Markus as he may have seen this happen before.
Beefy
PostPosted: Wed Sep 29, 2004 1:23 pm    Post subject: Reply with quote
Solly,
Have you loaded any new software on you PC or Laptop or PDA in the last three week period?
When you mention you can't sync, can you do ActiveSync?
As I mentioned before POI-Warner went weird with me causing ActiveSync to crash out after a couple of seconds. Although the syncing of the POI's worked fine. The only way I sorted this out was to do a full hard reset and then load everything on again. Soft Resets don't make any difference and de-installing the application and then re-installing doesn't work.
Up to you or you can wait for a response from Markus. I would say that the subject that I sent to Markus started "URGENT RESPONSE REQUIRED". This seemed to get a quick response.
Beefy
TomTom ONE
Solly
PostPosted: Wed Sep 29, 2004 8:34 pm    Post subject: Reply with quote
Beefy,
I do not remember loading any new stuff on either the PDA or laptop......however i can use activeSync as I use it all the time with AvantGo and Outlook.
I sent another email to markus and will wait a couple days. If all fails I will try a hard reset. Fingers crossed..........and a big thank you for the forums assistance
22.055 (29 May 24)
