digital Regular Visitor
Posted: Sat Dec 05, 2015 12:46 pm Post subject: TomTom Go 930 USB failure |
My Go930 is refusing to connect to any of my computers. They all show the same errors.
When plugging the USB lead in I get:
'The last USB device malfunctioned and Windows does not recognise it'
When it attempts to install drivers I get:
' Device descriptor request failed'.
Other than that it works fine as it will find satellites and compute a route.
Anyone able to offer a solution? _________________ Frank |
justbrowsing Frequent Visitor
Posted: Sat Dec 05, 2015 12:53 pm Post subject: |
Sounds more like a PC problem than a device hardware problem |
M8TJT The Other Tired Old Man
Posted: Sat Dec 05, 2015 12:56 pm Post subject: |
OP did say "any" implying more than one. PC problem? Probably not, especially if it has worked in the past. |
Joined: 30/12/2002 17:36:20 Posts: 4918 Location: Oxfordshire, England, UK
Posted: Sat Dec 05, 2015 4:56 pm Post subject: |
Obvious question: Whilst you've tried several computers, have you tried different USB cables?
Are you still able to charge the 930 in the car? IIRC the 930 charges by a mini USB cable. So if you can charge via the cable then the USB port on the 930 may be OK and not damaged?
Garmin Camper 770 LMT-D |
Posted: Sat Dec 05, 2015 6:26 pm Post subject: |
Thanks for the responses.
The problem is present on a Windows 10 desktop and laptop, a Windows 8.1 desktop and laptop, a Windows 7 laptop and a Windows 7 tablet. I would assume the problem lies with the TomTom.
I've tried two USB cables in 10+ USB sockets.
The TomTom will charge in all of those sockets and a mains adapter.
It has worked in all of the above scenarios in the past, the problem appeared from nowhere with nothing having changed in the way it was being used or set up.
It looks as though the response it gives when challenged by the computers isn't making sense: 'Device descriptor request failed'? _________________ Frank |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Sat Dec 05, 2015 7:51 pm Post subject: |
I have an iMac and a 530. When opening up to modify files, something I have done without trouble for years, I'm frequently getting the 'Disc not ejected properly' message. Also for years I have disconnected by clicking on the disconnect icon, but am now having to drag the external drive icon to the trash to get it to close properly. I have also found that I cannot now copy the contents of my 530 and 550 to my computer as it refuses to copy some files. I am running 10.10.5 software and had assumed that there is increasing incompatibility between the old TT software and the newer Apple software. _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Posted: Sat Dec 05, 2015 7:53 pm Post subject: |
OK .... IIRC my old 730 had an SD card slot, therefore I presume that the 930 has one too?
If the 930 has an SD card, have you:
1. Taken the SD card out and tried accessing via a card reader?
2. Take another SD card that's large enough and copy the latest back of the 930 onto it. You do have older backups of the 930 right?
As it's a problem on all PCs it does suggest that the 930 is the root of the problem. However to be sure, do all of the PCs that you've tried work OK? i.e. do all of the devices, especially USB devices work OK?
If that still doesn't work then all I can suggest is Google for "Device descriptor request failed" and see if anything works.
Posted: Sun Dec 06, 2015 3:14 pm Post subject: |
I'm using an SD card and SDHC in the 530 and a micro SDHC in the 550. I'm no genius - but whatever works... _________________ Mike R [aka Wyvern46]
exportman Frequent Visitor
Joined: Mar 26, 2006 Posts: 261 Location: United Kingdom
Posted: Sun Dec 06, 2015 4:27 pm Post subject: |
Very often the USB port on the device is the problem. The port is only connected at the sides the four data/power outlet from the rear port are just a dry connections. over time the port starts to move and they loose contact. |
Posted: Mon Dec 07, 2015 8:49 pm Post subject: |
exportman wrote: | Very often the USB port on the device is the problem. The port is only connected at the sides the four data/power outlet from the rear port are just a dry connections. over time the port starts to move and they loose contact. |
Thanks, looks like I need to dismantle it. _________________ Frank |
Posted: Wed Dec 09, 2015 8:01 pm Post subject: |
digital wrote: | exportman wrote: | Very often the USB port on the device is the problem. The port is only connected at the sides the four data/power outlet from the rear port are just a dry connections. over time the port starts to move and they loose contact. |
Thanks, looks like I need to dismantle it. |
If you strip it down and look, the USB socket will be soldered at the 4 corners.
I try to clamp the back edge to the circuit board then resolder the rear corners. If your hands are steady enough and you have the right soldering tools you may be able to solder the 4 pins to the boards but its very tricky. |
Posted: Thu Dec 10, 2015 12:14 pm Post subject: |
I'll give it a go, though my soldering iron has a poker as a first cousin! _________________ Frank |
