Pocket GPS World :: View topic - Numerous PCs won't see Nuvi 52LM on USB
PaulB2005
PostPosted: Fri Dec 04, 2015 12:28 pm    Post subject: Numerous PCs won't see Nuvi 52LM on USB Reply with quote
Having owned a Garmin i3 and a couple of Nuvi before switching to TT I'm used to troubleshooting these units. However this has got me stumped.
Its a family members Nuvi 52LM SW Version 4.00 UK & ROI
All was ok whilst she used an old Windows XP PC, I could update the software and maps without any issues. Even when she got a new Laptop with Windows 8 all was well but since upgrading to Windows 8.1 her laptop will no longer recognise the Nuvi is plugged in. The unit powers up and charges ok but Garmin Express, WebUpdater and Device Manager firmly state no device detected.
So far I've tried
- 2 x Windows 8.1 Laptops
- 1 x Windows 7 PC
- 3-4 USB cables (both Garmin and non-Garmin)
- The USB extension cable "trick" - didn't work!!
- Hard Reset - just wiped out all the favourites and settings
- Various USB ports (USB 2.0 & 3.0)
- Developer mode
- Installing Garmin Drivers
- Compatiblilty mode in Windows 7 & 8.1 to run Garmin Express as Windows XP SP3.
- Wiggling and checking cables are secure
- Just about all the tips and tricks I can Google.....
On one boot up it did show the PC icon which indicated it was entering a mode to communicate with the PC but then it booted normally......
Can anyone help?
Garmin can't.....
PostPosted: Fri Dec 04, 2015 12:56 pm    Post subject: Reply with quote
You could run through this FAQ but may have already done this
https://support.garmin.com/support/searchSupport/case.faces?caseId=%7B9b0aa260-3f4b-11e4-eaba-000000000000%7D
If you have exhausted that try these
http://www.techspot.com/community/topics/usb-drive-or-flash-problems-how-to-cleanup-and-remove-old-usb-storage-drivers.145884/
http://www.makeuseof.com/tag/external-drive-not-recognized-this-is-how-to-fix-it-in-windows/
PaulB2005
PostPosted: Fri Dec 04, 2015 1:50 pm    Post subject: Reply with quote
Thank you
The Garmin FAQ I've been through myself and Garmin have also emailed it to me.
I've pretty much tried all the windows tips.
It doesn't seem to be just me there seem to be quiet a few people suffering the same issue and some say that the Hard Reset worked for them. 've tried this 2 or 3 times now and no difference.
PostPosted: Fri Dec 04, 2015 2:00 pm    Post subject: Reply with quote
If Windows isn't recognising that a USB device has been plugged in (no double bong) on numerous PC's and various cables then all I can think of is a damaged Garmin mini USB port or internal connection.
Presumably other USB devices work just fine in the same ports.
Does it work OK in the car, charges and fires up automatically when it gets power?
Remove any SD card, if it accepts and has one.
Couple of extras here http://www.gpscity.com/questions?qid=44804
Satnav:
Car Average MPG :
PaulB2005
PostPosted: Fri Dec 04, 2015 3:20 pm    Post subject: Reply with quote
Hmm. Hadn't thought of that....
EDIT: Cant see any damage or obvious obstructions (fluff, grit etc)....
Yup. USB 2 and 3 ports all work fine. Ports even charge the Nuvi just not recognised as a device.
Yes.
No SD Card. Just tried inserting one. Made no difference
Cheers - this is one of the many pages I've been through already...
PostPosted: Fri Dec 04, 2015 3:46 pm    Post subject: Reply with quote
All this is pointing to an internal error, given that you've tried various PCs and cables and done a master reset.
PostPosted: Fri Dec 04, 2015 4:19 pm    Post subject: Reply with quote
Perhaps the Garmin driver is corrupt, but seems unlikely as it's happening on several computers. Confused
PostPosted: Fri Dec 04, 2015 4:26 pm    Post subject: Reply with quote
Nuvis don't need any drivers, just the standard Windows ones, so it won't be that Wink
PaulB2005
PostPosted: Fri Dec 04, 2015 6:00 pm    Post subject: Reply with quote
..and any drivers that might be needed are installed with Garmin Express and Garmin have already suggested downloading and installing the driver set. Needless to say it didn't work!!
Not my week this week with sat nav - can't work this problem out and having issues with the TT Traffic Subscription on my iPhone app....
PostPosted: Fri Dec 04, 2015 6:21 pm    Post subject: Reply with quote
Sussamb, what's that trick for switching out of MTP mode ?
Might work in standard USB device mode with a drive letter.
Satnav:
Car Average MPG :
PostPosted: Fri Dec 04, 2015 6:29 pm    Post subject: Reply with quote
Considered that but the 52 isn't an mtp mode device so is always in mass storage.
PostPosted: Fri Dec 04, 2015 8:37 pm    Post subject: Reply with quote
So it's always going to produce a drive letter. Sounding like a duff unit.
Satnav:
Car Average MPG :
alan_sh
PostPosted: Fri Dec 04, 2015 10:18 pm    Post subject: Reply with quote
Mine does this too. However, fi I hibernate (or shut down) my PC, plug in the Garmin and then boot it up, it works fine.
I have other Garmins that work fine.
I have no idea what is going on.
Alan
PaulB2005
PostPosted: Sat Dec 05, 2015 12:30 pm    Post subject: Reply with quote
Alan
Interesting.
So I tried this. Even messed about with the BIOS settings for power and USB. Didn't know I could charge things off my USB 2 ports if the tower is plugged in and on but not actually booted on!
Anyway what ever I do - no dice......
I'll mess about a bit more later.
PostPosted: Sat Dec 05, 2015 1:45 pm    Post subject: Reply with quote
This is the sort of problem I'd like to roll my sleeves up and get stuck in.
Very difficult and frustrating from afar
Satnav:
Car Average MPG :
