M8TJT The Other Tired Old Man
Posted: Wed Oct 21, 2015 9:03 am Post subject: |
Kremmen wrote: | It means that you haven't got the Microsoft.NET4 client pack installed. | Then why the hell didn't it say that? |
Posted: Wed Oct 21, 2015 9:07 am Post subject: |
OOPs. double post.
@kremmen. DEANO says he has NET4 installed though. |
Kremmen Pocket GPS Verifier
Posted: Wed Oct 21, 2015 10:35 am Post subject: |
Step 1 is to uninstall the 2013 version and install the latest 2015 version and see if it prompts for the download during install. If not the new one may accept the installed version.
There are a few versions of .NET4 but the client pack is the smallest one with all the required features.
That COM error points to a missing API link between the program and the PC. _________________ Satnav:
Car Average MPG :
DEANO3528 Lifetime Member
Posted: Wed Oct 21, 2015 11:16 pm Post subject: |
Haha. Thanks guy's.
I think part of the problem is the XP I am still plodding along with. PC is getting slower and slower so will need changing soon I think.
Trouble is, XP has been so reliable that it seems a shame to change 'just because'. |
Posted: Wed Oct 21, 2015 11:33 pm Post subject: |
But have you tried what Kremmen suggested in the first sentence of the post prior to yours? |
Posted: Wed Oct 21, 2015 11:37 pm Post subject: |
No not yet. Only local at the moment so don't need the database. When I next update the Garmin which will be week after next once back off hols, I'll do it then. |
Posted: Thu Oct 22, 2015 5:18 am Post subject: |
I'm going to update the program today as a few small bugs have been identified. The main processing is fine, it's the text change facility that has been modified.
It will be done by 07:00 _________________ Satnav:
Car Average MPG :
Allan_whoops Frequent Visitor
Posted: Thu Oct 22, 2015 7:59 am Post subject: |
I am not sure if other people have been getting this but I am getting this error
Error in create GPX module: Conversion from string "S-Gatso:54880" to type 'Integer' is not valid. 13 |
Posted: Thu Oct 22, 2015 8:04 am Post subject: |
Thanks for that.
The GPX module is before it gets to the new bit and is as it's been for ages so something odd with the data.
Which camera set are you using? .. and is this this weeks update?
As a blind guess before I investigate that line should have something like 12345@50 on the end of what you've posted so spaces is coming in where numbers are expected.
I'll find that camera and investigate. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 22, 2015 8:24 am Post subject: |
I've just downloaded the latest Garmin POILoader Speed Zoned set and it's run through OK.
I'm going to need a detailed walkthrough of what you've done.
Stop Press:
Camera 54880 is a dummy camera inserted by PGPSW to help prevent an empty file. It has no speed info attached to it.
I need to know what you've downloaded so I can reproduce the error and work round it. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 22, 2015 9:00 am Post subject: |
Easy way for this one is for MaFt to give it a speed |
Posted: Thu Oct 22, 2015 9:17 am Post subject: |
It is but I'm intruged as to why it's not in my download. Also if it's a dummy I'd like to ignore it.
At least it shows my error trapping worked with the correct data to find it. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 22, 2015 9:37 am Post subject: |
This happened in both last week's and this week's data. I downloaded
Garmin POILoader [UK - Speed Zoned Complete | pMobiles: Yes | French: No | Swiss: No ]
(13.013 - 21 Oct 15)
this morning.
It happens while processing the Gatso 60 entries. |
Posted: Thu Oct 22, 2015 10:11 am Post subject: |
Hmm
The only difference is you are downloading the pMobiles. I'll do the same. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 22, 2015 10:28 am Post subject: |
Got it.
It's in the Gatso_tba so the last successful file was the Gatso 60.
I'll code round this camera.
In the meantime the quick fix is to not process unverified cameras.
Unverified - Excluded. _________________ Satnav:
Car Average MPG :
