Pocket GPS World :: View topic - Which Download?
Which Download?
thetrouttickler
PostPosted: Fri Mar 20, 2015 10:46 am    Post subject: Which Download? Reply with quote
Hi, I'm new to this.
I have a 2013 Freelander 2 XS. Meridian sound system with built in sat nav. I'd like speed limits and speed camera locations installed. I have no idea which download to get, apart from it needs to be GPX format I think..
Thanks for the advice Embarassed
PostPosted: Fri Mar 20, 2015 11:20 am    Post subject: Reply with quote
I can't help directly, but the speed limit data is usually embedded in the map and is not a separate file that you can get from here. Whether they can be displayed is basically up to the satnav software designer, but perhaps someone els will come along and let you know if it can be done and how.
Have you looked at the compatibility list here?. Scroll down the page and you will find installation instructions for the PGPSW speed camera database for the Freelander.
Good luck.
thetrouttickler
PostPosted: Fri Mar 20, 2015 1:14 pm    Post subject: Reply with quote
Thanks for your help. File downloaded and extracted...just need to hunt out my USB.
On the file download tab, it says i can't play sounds? But the system can play mp4 etc as I have a music USB plugged in...I'm only after a beep of some sort when I'm in an unfamiliar area.
PostPosted: Fri Mar 20, 2015 2:55 pm    Post subject: Reply with quote
It tells you how to do the sounds in the instructions, or didn't it work for you?
