Pocket GPS World :: View topic - Switch to Micro SD card
Wizzardoz
PostPosted: Sat Feb 28, 2015 12:26 pm    Post subject: Switch to Micro SD card Reply with quote
I have a 2699LMT unit with only 60mb left but with a blank 8Gb micro card in it.
Is there a way to switch all files to the SD card so the satnav runs from the SD card? Can the folders be "split" so some of them reside on the SD card rather than the Satnav?
PostPosted: Sat Feb 28, 2015 12:31 pm    Post subject: Reply with quote
Not easily. What you can try first is delete all unwanted vehicle, voice, text, keyboard, help and EULA files. That should free up a fair bit of space.
A map update is due out next week. Almost certainly you will need the card for that!
Wizzardoz
PostPosted: Sat Feb 28, 2015 12:36 pm    Post subject: Reply with quote
Ok thanks for this. Can I assume that since I have an empty SD card in the satnav (empty as seen via my PC), Express will automatically use it for more space when maps are updated next week?
PostPosted: Sat Feb 28, 2015 12:56 pm    Post subject: Reply with quote
It'll use the card for the complete map if it won't fit internally. It doesn't split the map between the two.
Wizzardoz
PostPosted: Sat Feb 28, 2015 1:04 pm    Post subject: Reply with quote
Thanks. This is what I was hoping for! I will use a 16gb in case I need to add USA to my lifetime Europe ones.
22.054 (22 May 24)
