Pocket GPS World :: View topic - Card not recognised
Card not recognised
beefcarrot
PostPosted: Fri Aug 15, 2014 8:56 am    Post subject: Card not recognised Reply with quote
Hope this question isn't asked repeatedly elsewhere!
I have just purchased a 2598 and got an 8GB micro SD card to go with it. I have inserted said card but in Garmin Express, it's saying the internal memory is almost full and that I should insert an SD card.
I have checked the card and it's working fine on my PC.
Any suggestions?
Thanks everyone.
alan_sh
PostPosted: Fri Aug 15, 2014 9:01 am    Post subject: Reply with quote
I don't think Garmin Express recognises cards in any device.
[I assume you want to load maps on it]. What I do is download the maps to my computer and then use Mapsource to select the maps and then send them to my SD card. I think you can also use Mapupdater to do the same.
Alan
PostPosted: Fri Aug 15, 2014 3:19 pm    Post subject: Reply with quote
Actually Express will use the card. But you still get the message about needing the card even if you have one inserted. I assume you've loaded one in case it's needed? Its better to wait until it is and Express asks you specifically to do so during the map update process.
beefcarrot
PostPosted: Fri Aug 15, 2014 8:17 pm    Post subject: Reply with quote
Thank you - yes I bought one just in case, as I'd read some reviews saying I'd need one. Sounds like it's going to be less of a problem than I'd feared!
22.055 (29 May 24)
