Pocket GPS World :: View topic - What's wrong with these JPR files?
HDDC
PostPosted: Wed Jul 30, 2014 11:17 pm    Post subject: What's wrong with these JPR files? Reply with quote
1.000000000000000
0.000000000000000
0.000000000000000
-1.000000000000000
445000.500000000000000
1209999.500000000000000
nm=hp40ne
it=png
sc=50000
pr=Transverse Mercator
pp=-2.000000000
p1=49.000000000
p2=0.9996012717
p3=-100000.00
p4=400000.00
zn=t
dm=Ord Surv of Gr Britain 1936 (Mean)
1.000000000000000
0.000000000000000
0.000000000000000
-1.000000000000000
1204999.500000000000000
nm=hp40se
it=png
sc=50000
pp=-2.000000000
p1=49.000000000
p2=0.9996012717
p3=-100000.00
p4=400000.00
zn=t
These two JPR files are for tiles from OS Open Data. When imported, neither is calibrated, despite TFW information being included in the first 6 lines of each file as per the JPR spec. Each requires manual calibration but I'm planning on importing a lot of these. Can anyone explain what's going on? I'm using Memory Map Navigator (Euro) 2004.
PostPosted: Wed Jul 30, 2014 11:34 pm    Post subject: Reply with quote
Why start a new topic rather than continue with your previous one? They are both about pretty much the same thing.
HDDC
PostPosted: Thu Jul 31, 2014 7:49 am    Post subject: Reply with quote
I've changed this the files as follows, but still no luck:
zn=30V
M8TJT, This forum puts a "new topic" button right next to the "reply" button :P
PostPosted: Thu Jul 31, 2014 7:59 am    Post subject: Reply with quote
Very Happy But at least you found it rather that the 'Quote' button which a lot of people use, quoting a chain of posts from time immemorial Laughing
HDDC
PostPosted: Thu Jul 31, 2014 8:11 am    Post subject: Reply with quote
I just found this sample file which works perfectly:
nm=margate.
pr=equirectangular
it=png
sr=254
st=0.000000
sn=0.000000
dm=WGS84
rp1=51.399206,1.362305,0,0
rp2=51.399206,1.461182,2304,0
rp3=51.344339,1.461182,2304,2048
rp4=51.344339,1.362305,0,2048
vp1=0,0
vp2=2304,0
vp3=2304,2048
vp4=0,2048
vg1=51.399206,1.362305
vg2=51.399206,1.461182
vg3=51.344339,1.461182
vg4=51.344339,1.362305
It's somewhat different to mine, and different to the documentation I found, but it works Smile The file which goes with it is a TIFF at 2304 x 2048
PostPosted: Thu Jul 31, 2014 8:16 am    Post subject: Reply with quote
Different projection, but that doesn't explain the first 6 lines without the '=' in your first post.
HDDC
PostPosted: Thu Jul 31, 2014 11:50 am    Post subject: Reply with quote
This seems to work,. It it omits the TFW section entirely and requires a conversion to LAT/LONG. It imports fully scaled and calibrated, although I don't yet know if it's done correctly:
nm=hp40se
it=png
un=meters
sc=50000
pp=-2.000000000
p1=49.000000000
p2=0.9996012717
p3=-100000.00
p4=400000.00
rp1=60.725606 -1.176947,0,0
rp2=60.725606 -1.084026,5000,0
rp3=60.769939 -1.084026,5000,5000
rp4=60.769939 -1.176947,0,5000
vp1=0,0
vp2=5000,0
vp3=5000,5000
vp4=0,5000
vg1=60.725606 -1.176947
vg2=60.725606 -1.084026
vg3=60.769939 -1.084026
vg4=60.769939 -1.176947
dales
PostPosted: Fri Aug 01, 2014 1:41 am    Post subject: Reply with quote
What data are you accessing (from OS open data)?
The Streetview files I downloaded were in tif format, so no problem for MM.
Dales.
