Kwakers Lifetime Member
Posted: Wed Apr 16, 2014 8:31 am Post subject: nuvi 660 lost sound |
I used at nav last week and on outward trip all was fine but for my return despite turning up volume to full or anywhere between on or off I could not get any sound. Mute is unchecked and I loaded some music onto a card and this also does not work.
Anyone else had this problem or any suggestions ?
Bob |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 564 Location: North Devon
Posted: Wed Apr 16, 2014 11:25 pm Post subject: Re: nuvi 660 lost sound |
Kwakers wrote: | Mute is unchecked and I loaded some music onto a card and this also does not work.
The fact that both Navigation sounds and Music playback are affected, would make me suspicious that this is a hardware fault. It could be the speaker, or even the headphone jack (since that contains a switch that disconnects the speaker).
Do you get audio from the headphone jack?
There are some audio diagnostics you could try. I can't remember the exact details for invoking them on this model - hold the battery icon - or possibly the 'Time', for about 7 seconds until they appear. If you keep pressing "Next" you should find a page of audio related tests.
To exit the tests, you'll probably have to press the Reset button on the back.
Posted: Fri Apr 18, 2014 8:52 am Post subject: |
found the problem. After dismantling the unit the connector for the jack plug fell out .Re soldering should do the trick  |
Posted: Fri Apr 18, 2014 9:15 am Post subject: |
That sure could be the problem  |
