Pocket GPS World :: View topic - Nuvi 3598 maps
Nuvi 3598 maps
Goto page Previous  1, 2
djc1610
PostPosted: Fri Mar 28, 2014 6:52 pm    Post subject: Reply with quote
Success at last.
I did a hard reset and then I copied the North America maps from the "Map" folder on the sdcard to a (new) "Map" folder on the internal drive and to my utter amazement I can now access the North America map
and........
When I use "Where To" and then "Address" I am shown a window that first asks for a country.
So I am very happy now.
Many thanks sussamb you have been so very helpful.
VW RNS 510 and TomTom 5200 World
cwog
PostPosted: Sat Mar 29, 2014 3:58 pm    Post subject: Reply with quote
Please will you now check to see if you can search for an address in mainland France as I outlined earlier in the thread - Thanks
djc1610
PostPosted: Sat Mar 29, 2014 6:53 pm    Post subject: Reply with quote
cwog wrote:
In the name of pure research please will you:
with all the maps enables (ie ticked)
try and select an address in France by the following method.
select "Where To" on the first screen
Then "Address"
Then "Change Country"
Then type "France" it may offer you a list of countries with just the F typed
Select "France"
Then does it give you only the following States or Provinces
Guadeloupe, Guyane, Martinique, Saint-Barthelemy
if so you have the bug as I and others have.
If it allows you to Spell City, or Spell Postal Code or Search All, then the bug is not in your version of the firmware.
To actually set destinations in France (Should you wish to travel there) you will have to deselect the North American maps.
Please let us know what result you get.
Hi I did as requested and after I enter France I get all of France. i checked this by typing several known addresses across France.
Mine seems to work OK.
I hope this is helpful to you.
cwog
PostPosted: Sun Mar 30, 2014 10:11 am    Post subject: Reply with quote
Thank you - a few weeks a go some of is discovered that the French mainland data did not show up when the North American maps were ticked.
djc1610
PostPosted: Sun Mar 30, 2014 10:57 am    Post subject: Reply with quote
It all seems rather odd and confusing.
With the USA map on the sdcard and map ticked (therefore recognised by the software) the map would not work. Transferring the USA map to the internal memory solved the problem.
It seems that these rype of problems will always arrive when changes to the map, software and hardware are made.
We will always need a forum such as this to resolve our problems.
Long may Pocket GPS World survive and flourish.
djc1610
PostPosted: Sun Mar 30, 2014 11:06 am    Post subject: Reply with quote
I have just resolved another problem and this time it was converting pois in ov2 format to nuvi format.
Several of my pois failed to convert satisfactorily.
I tried gpx and the csv formats but neither solved the problem.
I then looked at these problem poi files in MS Word and all seemed OK.
I next looked at them in MS Excel and I was surprised to see that the pois covered many more columns than I had expected.
Going back to Word I found that the description of the individual pois contained an address with sections of the address separated with commas and it was these commas that was causing the problem. Removing the unwanted commas in the pois but leaving the essential ones took some time but now all my pois work correctly on my 3598.
Page 2 of 2
