eggplant Occasional Visitor
Posted: Wed Sep 15, 2004 3:31 pm Post subject: outlook/contacts/tomtom |
Hi all,
I've just decided to use my outlook contacts from my pc to enable me to navigate to an address, however, I synched them and it doesnt work !! It sends me to some bizarre address, can anyone offer any assistance?
Thanks |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Wed Sep 15, 2004 4:47 pm Post subject: |
TomTom has a very special (some say ignorant) way how to record street addresses. Your Outlook contacts may not be in the "right" (according to TomTom) format.
Make a test - go to one of the locations and see how TomTom writes the street name and house number. Then store this as a contact. Then try to navigate to it. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Sep 15, 2004 6:26 pm Post subject: |
Thanks for the reply, I dont quite get what you mean by go to one of the locations and see how tomtom records it ?
I have no contacts at the minute, just trying to add some, simply because all my favorites are full.
One example is:
Chadwick St
Glossop
derbyshire
Sk13 8ef
Thats is a customer location, if I enter the postcode manually, or use ukpostcode, its fine, but if I try and go there from my contacts, it tries to send me to:
St Cuthberts square
GlosterHill
Northumberland
TD15 2
thats like MILES in the opposite direction !
I tried it with my home address (which I wont post for obvious reasons) and it tries to send me about 300 miles away !!
Thanks |
Parky Regular Visitor
![](modules/Forums/images/avatars/avatar_ani_013.gif)
Joined: 25/05/2003 09:12:02 Posts: 247 Location: Bradford UK
Posted: Thu Sep 16, 2004 8:56 am Post subject: |
The way that TTN uses outlook for addresses is useless, to say the least. TTN reads from Outlook in a very specific way, which is usually different to the default way you input addresses into Outlook.
I found that in nearly all cases, I had to amend addresses in Outlook so TTN could read them correctly. Not what you want to do when you need a quick look up.
For me, I would forget trying to use Outlook and TTN3 for addresses. |
Posted: Thu Sep 16, 2004 7:01 pm Post subject: |
thanks for the reply, the problem is, I really need access to addresses, and unfortunately 20 favorites isnt enough, I suppose I could manually look at the contact and do it that way but thats a bit of a pain, any other way to do it? any way to increase number of favorites?
Thanks |
Posted: Thu Sep 16, 2004 7:11 pm Post subject: |
you can use a different program - most of the others are way more relaxed than TomTom when it comes to address formats. _________________ Lutz
Talkingbollox Frequent Visitor
![](modules/Forums/images/avatars/1669536683418e9e94aaf72.gif)
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
Posted: Thu Sep 16, 2004 9:46 pm Post subject: |
eggplant
These are the other options:
- create a separate POI file with all of your contact addresses
- type in the postcode from your contacts into Niel Thomsen's excellent UKPostcode program |
Posted: Thu Sep 16, 2004 11:38 pm Post subject: |
ok, thats a cool idea, then i can of course navigate to a poi
BUT
how the heck do i create a poi? I've now been tring this for the last 3 hours!
thanks |
Posted: Fri Sep 17, 2004 7:07 am Post subject: |
This is how I create POI for addresses I use. First, use Niel's superb UK Post code program to into the post code. In that program use "show on map" which will start TTN3 in map mode. On the TTN map screen press and hold on the curser point and this will bring up a list of options. Click on "Add as point of Interest", this will bring up another screen where you can add to an existing POI group, or create another POI group, I call mine "Work Contacts"
Thats it, done. You can now navigate to your specific POI. |
Posted: Fri Sep 17, 2004 6:59 pm Post subject: |
many thanks for the reply, I'm almost there! The only thing I'm struggling with now, is when I get to the part where I can add it, thats fine, but I can only add it to and existing group, I dont see the option to create a new group? Am I just being thick ??
Thanks again |
Posted: Fri Sep 17, 2004 8:34 pm Post subject: |
Tap on the drop down box in "type", then scroll to the top for <new type>, type in name of your choice. |
Posted: Sat Sep 18, 2004 12:50 am Post subject: |
ok, i really must be having a dense moment, my first item is "abbey", i scrolled right down the list but see no option for "new type" |
Beefy Regular Visitor
![](modules/Forums/images/avatars/333137774415e75835a607.jpg)
Joined: Aug 06, 2004 Posts: 107 Location: Bucks, United Kingdom
Posted: Sat Sep 18, 2004 10:55 am Post subject: |
nothing above abbey ![Question](modules/Forums/images/smiles/icon_question.gif) |
