black_cabbie Occasional Visitor
Posted: Thu Sep 09, 2004 10:47 am Post subject: TT3 for Benelux with French names! |
I have the CD for benelux. When I do the installation, I am not asked if I want french or dutch names for the maps. it installs Dutch names.
What am I doing wrong?
George |
joejoe123 Occasional Visitor
Joined: Mar 06, 2004 Posts: 39 Location: Vienna , Austria
Posted: Thu Sep 09, 2004 8:34 pm Post subject: |
I guess map names are decided by tomtom but if you want to change the map names do the following.
if you want to change the benelux map name go to file explorer and navigate to your storage card , open the benelux folder and there will be 2 files called "Benelux" , press and hold and then rename the file to anything you want but both files must have the same name, otherwise tomtom will not find the maps.
try it at your own risk , if you have any troubles just rename them back to the original name. |
Posted: Fri Sep 10, 2004 7:04 am Post subject: |
Thanks for the reply.
Could it be that there is a french road version and a Dutch? Because I've tried anything and still the name of the roads appear in Dutch! |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Fri Sep 10, 2004 9:01 am Post subject: |
black_cabbie,
I don't have TT3 but I know that on TT2 EuroMaps there are both French and Dutch versions of the Benelux maps on CD1. You have to load the correct version off the CD. _________________ Kam |
Posted: Fri Sep 10, 2004 11:32 am Post subject: |
On TT2 during the installation you were prompted to either install french or dutch names. On TT3 it installs Dutch no matter what you do. I was hoping there was a french version but so far I haven't been able to find a solution. Maybe I have to send a mail to Tomtom support. |
Posted: Fri Sep 10, 2004 3:39 pm Post subject: |
black_cabbie wrote: |
i do not think you can change the names of the roads , names are names ,
if you are in france you have french names and in germany you have german names.
if you have an address from The netherlands ,sure you have it in dutch. |
andrewh Regular Visitor
Posted: Mon Sep 13, 2004 11:49 am Post subject: |
It is very simple but you need to know. If you choose French names then it will use French names in Bruxelles. If you choose Dutch names then it will use Dutch names in Brussel.
Bruseels is officially a bi-lingual city so both map sets are required as all names are gicn in both languages on paper maps. It would take too much space to do this on Tomtom.
HTH
Andrew |
TonyP Regular Visitor
Joined: 07/01/2003 17:12:34 Posts: 94 Location: Belgium
Posted: Tue Sep 14, 2004 7:38 pm Post subject: |
andrewh wrote: | It is very simple but you need to know. If you choose French names then it will use French names in Bruxelles. If you choose Dutch names then it will use Dutch names in Brussel.
HTH
Andrew |
But how do you do this in V3? In V2 it offered the choice, but I get the Dutch names in V3 as well.
The problem is that although Brussels is officially bilingual, everyone invariably uses the French street names, and it is not easy to guess what the Dutch version is, even if you speak Dutch. |
Posted: Wed Sep 15, 2004 11:26 am Post subject: |
I use the Palm version where both are on the CD and I had to choose before loading to a card.
Certainly difficult to work out Brussels names from one langauge to another!
Andrew |
Posted: Wed Sep 15, 2004 11:48 am Post subject: |
OK, I've got it!
The Benelux maps are on 2 Cds, CD1 is the dutch names and CD2 is the French names. There is nothing that indicates this, so everyone installs CD1 and gets the Dutch names. |
Posted: Mon Oct 04, 2004 6:07 pm Post subject: |
lovely!!! So now I just need to find the 2nd CD of Benelux..... |
