Pocket GPS World :: View topic - ARTICLE COMMENTS: Software Features
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: ARTICLE COMMENTS: Software Features Reply with quote
Please post any comments about the Software Features Article in this message
Mark R Penn
Small point, but some of the features listed as "no" for Navigator, actually are present:
Map matching (standard now, not an option as before)
Correct GPS Position (if you mean re-calibrate)
Heads up (standard in Navigator view, but not available in map view)
And one you say is available, but I can't find: Waypoints, unless you mean favourites, but you list that separately?
If you choose not to decide, you still have made a choice.
Thanks Mark for spotting those errors, I've amended the article and posted it to the website.
timtim
Another minor one - Reverse route is listed as 'No' for TomTom, but you can do it if you plan your route via the map A-B option on the 'Type' tab. It's fiddly I admit, but it's there.
It seems I don't know anything after all
NickG
PostPosted: Mon Nov 10, 2003 1:39 am    Post subject: Reply with quote
Why are the TTFF times listed for each software package? Surely these are only dependent on the hardware; the software has nothing to do with aquiring the fix - it simply waits for the NMEA signal to start streaming from the hardware?
Nick...
Blackbird
PostPosted: Wed Sep 22, 2004 11:13 pm    Post subject: Updating Reviews with Databases Reply with quote
As I already did mention, a comparative review is a snapshot in time.
This review is a good example. May I suggest to keep the comparisons updated. To compare things NOW, it is imperative to be able to compare relative evaluations which are up to date.
Idea
This can be done by using databases. Some "fields" in a database could be allocated to give "points" (e.g 8/10) for each important feature. Those evaluations should be readjusted in time, according the relative values compared to other products.
23.091 (03 Sep 25)
