Pocket GPS World :: View topic - PGPS camera database on GO 1005
psyskiesman
PostPosted: Fri Mar 22, 2013 10:18 pm    Post subject: PGPS camera database on GO 1005 Reply with quote
I have installed the PGPS camera database on my Go 1005, but they are showing on the map as red squares, which I believe are TomTom's camera icons. Question is, how do I get rid of the TomTom icons?
PostPosted: Fri Mar 22, 2013 10:59 pm    Post subject: Reply with quote
No, red squares are not the TT camera icons, they just mean you don't have any icon loaded for that POI type.
Looks like you have not uploaded the .bmp files for the PGPSW cameras.
"Settling in nicely" ;-)
psyskiesman
PostPosted: Fri Mar 22, 2013 11:02 pm    Post subject: Reply with quote
OK, I'll check that out in the morning. Thanks.
psyskiesman
PostPosted: Sat Mar 23, 2013 9:35 pm    Post subject: Reply with quote
I had downloaded the 44x44 bmp's and on checking the unit again it was showing the red squares on the map, but the correct icons in the top left of the screen. I added the smaller bmp's (22x22?) and everything is now OK.
PostPosted: Sun Mar 24, 2013 5:40 pm    Post subject: Reply with quote
That's right, those 44x44 icons are ONLY used in the top left of the screen during a warning.
If you don't have them the smaller icons are scaled up to do that job, but it doesn't work the other way round.
On the newer TomTom models (Go1000/2000 VIA etc.) you CAN use 44x44 icons for POIs if you want, but the ones downloaded for the PGPSW cameras won't work unless you rename them, as they are currently called "pocketgps.....X2".bmp to show they are double-sized for the top-left corner display.
psyskiesman
PostPosted: Wed Mar 27, 2013 7:34 pm    Post subject: Reply with quote
Thanks for the update, but what would I rename them?
PostPosted: Wed Mar 27, 2013 8:19 pm    Post subject: Reply with quote
The same name as the corresponding OV2 File. Without the '_X2' bit.
psyskiesman
PostPosted: Wed Mar 27, 2013 8:29 pm    Post subject: Reply with quote
OK, I'll maybe try that at the weekend. Wife already complaining that TomTom gets more time and attention than her! Heh Heh!
PostPosted: Wed Mar 27, 2013 8:58 pm    Post subject: Reply with quote
Well sit her down in front of East Enders, that should placate her Very Happy Very Happy
PostPosted: Thu Mar 28, 2013 11:55 am    Post subject: Reply with quote
So just to summarise...
The PGPSW database download includes:
1. The "standard" sized icons (which are already called the same names as the camera data files.
2. The double-sized icons (with "X2" at the end of the file names)
Both will normally get used with no fiddling around - the standard icon gets used on the map and driving view, and the big one in the top left for warnings.
Rules:
1. You MUST always have a set of icons with the same names as the camera data files otherwise you get red squares. (that's where you were going wrong originally - they were missing for some reason).
2. On the newer "NAV3" TomToms like yours, *if you wish* you can use large icons to replace the standard ones completely. To do that, you rename them with the names that standard icons had.
