lesnorthshields Occasional Visitor
Posted: Fri Jan 11, 2013 9:32 am Post subject: Android 4 via blue tooth to parrot, warnings cut off phone |
I regularly drive with my android playing music, copilot navigation and cameralerts also running in the back ground. The cameraalerts cut off phone converstions as the parrot apparently recognises the output from cameralert as a phone call. Speech from copilot does not do this. The parrot reports a bluetooth audio feed when copilot speaks, but reports a phone call when cameralert speaks a warning. I regularly drive without navigation, but keep cameralert running, this isn't possible unless I remove bluetooth audio output from the android and use its internal speakers, however this aslo stops the music stream to the parrot... Modifiaction to software please? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Fri Jan 11, 2013 10:59 am Post subject: |
In the CamerAlert settings what do you have the audio output set to use?
MaFt |
lbendlin Pocket GPS Staff
Posted: Sun Jan 13, 2013 1:41 pm Post subject: |
To extend on that - you should NOT set it to "Bluetooth Headset". Leave it at "Default" _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jan 14, 2013 9:16 am Post subject: Camera Alert on Android bluetooth |
Thanks, I set it to default wnd that works, Co-Pilot doesn't offer this facility so when it calls instructions out the music does not re-start. I'm waiting for a fix from them, then it will work as intended. |
