jlw Frequent Visitor
![](http://blodsugare.se/avatar/pocketgpsworld.jpg)
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Wed Jul 28, 2004 12:32 am Post subject: Remove NAG screen,,,, |
Is it possible to remove the enoying nag screen that pop ups while starting destinator 3?
I hate it! _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case |
TMF Occasional Visitor
Joined: Jul 27, 2004 Posts: 3 Location: Sydney, Australia
Posted: Wed Jul 28, 2004 12:41 am Post subject: |
I hate it as well, just a waste of time. Once would be enough! _________________ HP 2210
Destinator 3
Leadtek 9537
512MB CF
512MB SD |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Wed Jul 28, 2004 7:01 am Post subject: |
Unfortunately not, most of the applications have this, although some are a little more user friendly and allow you to tick a box to tell it to go away from now on. |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Wed Aug 18, 2004 5:49 pm Post subject: |
There are some news in this area. A german guy has programmed a little applet that you need to put into the destinator directory and start instead of Destinator. It will auto-answer the nag screen and the quitting confirmation request.
http://www.koolplaya.de/desti/DestiRobot/ _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
peeved Occasional Visitor
Posted: Tue Aug 24, 2004 12:37 pm Post subject: |
Lutz
How does one get the applet to to show in the Start Menu please? I have put it into the destinator directory but cannot get it to show in the program menu or start menu. Destinator does but not the destirobot.exe
Paul |
Posted: Tue Aug 24, 2004 1:40 pm Post subject: |
in file explorer, navigate to \destinatorapps\destinator.
tap and hold destirobot.exe.
tap on copy.
then change directory to \windows\startup\programs (or wherever you want the shortcut to be)
tap on edit > paste shortcut.
Optionally rename the shortcut, and remove the shortcut to Destinator. _________________ Lutz
Posted: Tue Aug 24, 2004 2:46 pm Post subject: |
Thank you very much, I was putting it into the wrong folder in Windows!
Paul |
Posted: Tue Aug 24, 2004 3:49 pm Post subject: |
oops, there's a typo in my post.
should read \windows\start menu\programs. _________________ Lutz
GPSinC3 Lifetime Member
![](modules/Forums/images/avatars/gallery/simpsons17.jpg)
Posted: Wed Aug 25, 2004 10:24 pm Post subject: |
Thanks to whoever wrote this, neat piece of code which works well. Assign it to a button and its a one push start to Destinator :D :D :D |
djhonline Occasional Visitor
Posted: Sun Sep 05, 2004 3:46 pm Post subject: |
Though it does kick you straight out when you go to close - before you can answer "Are you sure you want to quit Destinator" which I miss! |
Posted: Sun Sep 05, 2004 5:34 pm Post subject: |
Two versions of the program are available - the old version will not auto-answer the closing question _________________ Lutz
Sso Occasional Visitor
Posted: Wed Nov 17, 2004 3:11 pm Post subject: |
Tested both versions and they worked fine, but next time I tried to start destinator I got a popup saying "Unregistered version of Destinator, do you want to register?" with Yes/no-buttons. Do I just need to enter the regcode again or do I have a serious problem?
/Stefan |
Posted: Wed Nov 17, 2004 3:33 pm Post subject: |
should not be anything serious - try entering the code again. _________________ Lutz
Posted: Tue Nov 23, 2004 1:46 pm Post subject: |
Unfortunatly it seems that I have a bigger issue.
Looks like my deviceID has changed, because it isn't the same as on my registered activation at Destinators website.
Do I need to use "Move licence to a different device" to get it to work?
Thanks for your help!
/Stefan |
Posted: Tue Nov 23, 2004 3:18 pm Post subject: |
Your device ID has changed? is it a Toshiba?
Yes,transferring the license should fix the issue. _________________ Lutz
