Pocket GPS World :: View topic - No alert sound after upgrade to 1.3.6
PostPosted: Thu Jul 26, 2012 3:55 pm    Post subject: Reply with quote
The Bluetooth option in the audio route settings is for Bluetooth Headset Profile (HSP) which is different to the Bluetooth Handsfree Profile (HFP)
My Nokia CK-7W car kit uses HFP and so does not (if I recall correctly) work with CamerAlert.
To use A2DP you do not need to choose the Bluetooth output button, just use the 'default' notes button.
Adamantium
PostPosted: Fri Jul 27, 2012 12:33 pm    Post subject: Reply with quote
only tried it in my audi.
my gtr has a2dp, but I run that connected by cable to the headunit.
In the Audi, there is no A2DP, only headset protocol. It interrupts the sound and tells me there's a call, but there's no volume, no matter wha the volume on the relative volume slider.
I'll try it again to see if there are any relevant conditions.
I could also plug it in via the audi music interface, but I rarely bother, hence wanting to leave it in the bluetooth setting.
lbendlin
PostPosted: Sun Jul 29, 2012 4:04 am    Post subject: Reply with quote
Can you do voice control from the Audi to the iphone via the BT connection?
Lutz
TomTom/TeleAtlas NAVTEQ
CA_1020071845
PostPosted: Mon Jul 30, 2012 10:42 am    Post subject: Bluetooth doesn't work Reply with quote
I have tried Bluetooth Connection on my iPhone 4S in my Mercedes and it does not work after I have received or made a telephone call? I presume this is another bug?
lbendlin
PostPosted: Mon Jul 30, 2012 12:12 pm    Post subject: Reply with quote
You could call it a bug but it really is just another side effect of the BT Headset hack. Your incoming call uses the same audio route and the combination of your phone OS and your car BT implementation defines how such a conflict is handled.
Lutz
CA_1020071845
PostPosted: Tue Jul 31, 2012 11:04 pm    Post subject: Bluetooth Reply with quote
Ok thanks, so what should I do?
lbendlin
PostPosted: Wed Aug 01, 2012 12:43 am    Post subject: Reply with quote
Give us your car and your phone so we can test that combination...
Lutz
CA_1020071845
PostPosted: Wed Aug 01, 2012 12:48 pm    Post subject: Reply with quote
It's iPhone 4s and Mercedes CLC. Actually even when not on Bluetooth there are no alerts after I've received a bluetooth call. Thank you
PaulB2005
PostPosted: Wed Aug 01, 2012 1:09 pm    Post subject: Reply with quote
CAn you explain that a bit more clearly?
lbendlin
PostPosted: Wed Aug 01, 2012 6:24 pm    Post subject: Reply with quote
No, I meant (as a joke) give us your physical car and phone so we can physically test it. We only have mediocre/old cars and cannot realistically test all combinations, especially all the butchered Bluetooth implementations that car manufacturers put into their vehicles.
Lutz
lbendlin
PostPosted: Wed Aug 01, 2012 9:31 pm    Post subject: Reply with quote
Lutz
CA_1020071845
PostPosted: Thu Aug 02, 2012 4:54 pm    Post subject: Reply with quote
That seems odd because in the last proper version of the app, when I received a phone call over Bluetooth, the speed camera warning also played over Bluetooth through my car stereo. The rest of the time, the warning sound came from my iPhone. So maybe it's not my system but the way the app is configured.
lbendlin
PostPosted: Thu Aug 02, 2012 8:28 pm    Post subject: Reply with quote
There was no BT headset routing option in the "last proper" version.
Lutz
CA_1020071845
PostPosted: Fri Aug 03, 2012 10:33 am    Post subject: Reply with quote
And why is it that now even when not using Bluetooth for the app, I still don't get any speed camera warnings after I've received a phone call (on the same iphone) on Bluetooth?
lbendlin
PostPosted: Fri Aug 03, 2012 12:33 pm    Post subject: Reply with quote
That is a valid concern, we are already investigating. Will let you know as soon as we found the cause.
Lutz
Page 2 of 3
