Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 67, 68, 69 ... 75, 76, 77  Next
borgmaster
PostPosted: Fri May 18, 2012 4:15 pm    Post subject: Reply with quote
I had googled the problem and tried that solution. Vista home premium does not have gpedit installed. Any other solutions???
PostPosted: Fri May 18, 2012 4:55 pm    Post subject: Reply with quote
Have you tried this one? But it seems to relate to installing rather than just running. Sad
borgmaster
PostPosted: Fri May 18, 2012 5:39 pm    Post subject: Reply with quote
Thanks for that I have tried that before and it has not worked to resolve the issue at startup. I also did something similar in FF as the problem started when I installed FF12, however this also did not prevent CM asking for a digital sign at startup.
walkerx
PostPosted: Sun Jul 15, 2012 12:46 am    Post subject: Reply with quote
downloaded app to see if would help for setting up my poi and it just hangs - removed registry settings and restarted and got further
not sure what it's doing but the minute you point it to a folder it's creating files
PocketGPS_SC_Gatso.tmp - 3mb
PocketGPS_SC_Overspeed.tmp - 4mb
this is along with other files, but it is extremely slow (running on i7-2600k, 16gb ram) in whateva it is doing
PaulB2005
PostPosted: Sun Jul 15, 2012 9:53 am    Post subject: Reply with quote
It's generating files called GPX files which are large in comparison with the original CSV files. Not sure why it's taking so long on your PC though.
deeranwith
PostPosted: Sun Jul 15, 2012 10:37 am    Post subject: Reply with quote
I does on my machine. Sometimes up to 5 mins - just put it down to having to do some work! Very Happy
walkerx
PostPosted: Sun Jul 15, 2012 3:19 pm    Post subject: Reply with quote
yeh, not sure why was taking ages
when it's generating the files is it taking the format from when you last downloaded
ie uk zoned complete with wav voices
or does it use a preset version it will download
dales
PostPosted: Sun Jul 15, 2012 6:02 pm    Post subject: Reply with quote
Yes it downloads its own version ie speedzoned complete, for the countries you've selected, plus pmobiles if selected, plus its own voice components if selected.
Dales
walkerx
PostPosted: Sun Jul 15, 2012 9:05 pm    Post subject: Reply with quote
i like the voices from the uk zoned complete i download - how do i get it to use them instead of it making it's own
dales
PostPosted: Mon Jul 16, 2012 11:53 am    Post subject: Reply with quote
A bit of work, I'm afraid.
Beacause CameraManager has its own way of naming the camera files and icon files, then all the voice (wav) files have to be renamed to match.
You need to end up with sets of files (.bmp, .gpx and .wav) all named the same, like this:
PocketGPS_SC_Gatso_Fifty.gpx
PocketGPS_SC_Gatso_Fifty.wav
Dales
walkerx
PostPosted: Mon Jul 16, 2012 6:28 pm    Post subject: Reply with quote
Dales
thanks for the info on that - i'm rebuilding the database so it splits it into speed/camera type and direction.
just trying to work out when it gives a value
PocketGPS_SC_Gatso.gpx
PocketGPS_SC_Specs.gpx
If these are unverified or variable speeds
As using the sounds from the UK Zoned Complete download
Also noticed it may output the following
PocketGPS_SC_Specs_Fifty
but not
PocketGPS_SC_Specs_Sixty
even though it will have PocketGPS_SC_Specs_Sixty_E
Also what is PocketGPS_SC_Overspeed for, are these certain cameras or for warning if you over the speed limit
dales
PostPosted: Mon Jul 16, 2012 8:16 pm    Post subject: Reply with quote
I'd guess that the ones without specified speed-limits, are either variable limits or where there has been an (as yet) unverified report of a change to the limit.
I guess the missing voice file, is because there is no camera of that exact description in that week's download.
The Overspeed voice file is described on the Timings page of Camera Manager. It is a secondary warning, and, if selected, it will chime if you are near a camera and over the set limit.
walkerx
PostPosted: Mon Jul 16, 2012 9:03 pm    Post subject: Reply with quote
thanks again
I've got all my voices created from the UK Zoned Complete download and saved them off to another folder along with my modded icons
this has created a 56.3mb file so will post if this works
PostPosted: Tue Jul 17, 2012 6:37 am    Post subject: Reply with quote
I've just looked through my GPX file list to check sizes. The largest is the Gatso30 weighing in at 2,084Kb whilst in comparison my Gatso50 is only 221Kb and is not the smallest.
ps: This is using my GPX converter, not Ash's
walkerx
PostPosted: Tue Jul 17, 2012 8:04 pm    Post subject: Reply with quote
I think the reason it's taking ages is because of the download speed from pocketgpsworld.
For some reason it is extremely slow download compared to downloading stuff from other websites
even downloading the 19mb database itself took ages - so either the servers are busy, upload limit from server or bt preventing fast download from site
Page 68 of 77
