Pocket GPS World :: View topic - Cable won't work any more Etrex Cammo
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
tonyfendall
PostPosted: Sun Aug 29, 2004 8:53 pm    Post subject: Cable won't work any more Etrex Cammo Reply with quote
Anyone any ideas why my cable won't connect anymore.
3 pins have continuity but the power pin next to the orientation slot has no continuity.
I don't know if this matters.
Was working fine 3 weeks ago, now no good.
Have tried on COM 2 but no good.
Other devices on COM 1 and 2 are OK.
Any help appreciated.
Tony Crying or Very sad
Pc-Mobile
PostPosted: Mon Aug 30, 2004 4:57 am    Post subject: Reply with quote
Have you made any change to your PC/GPS or added any new software?
You have to configured your software/GPS again if you have made any change.
It is very unlikely that your cable stops working. Power pin is not needed.
It is likely that you have hardware/software com port conflict.
You should know which com port the cable is connected to (it should be com 1 or com 2, if you are trying both, it means you do not know which one is it).
If your software is configured to use the correct com port and it did not work, it is very likely that other software is occupying the com port thus preventing other software from using that com port.
Of course there is still the possibility that the cable is faulty. As you said the 3 pins have continuity so it should be OK.
Pc-Mobile
http://pc-mobile.net/gps.htm
PostPosted: Mon Aug 30, 2004 1:27 pm    Post subject: Reply with quote
It's probably either a configuration problem on the PC, or you have re-configured the eTrex at some point to go back to Garmin Protocol rather than exporting NMEA (which is required).
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.062 (12 Jun 24)
