Pocket GPS World :: View topic - Pretec CompactGPS + Ext Ant
mstockha
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Pretec CompactGPS + Ext Ant Reply with quote
I am the proud owner of the above, and use it religiously. My question is, how much of an improvement in signal strength, no of satellites detected / locked and persistance of lock do you experience with the external antenna? I mostly use it in the car. Comments welcome before I part with my cash!
Mark
Why me?
ipaq 3630, Pretec CF GPS, Ipaq 5550 Fortuna Slim GPS, TTNAV 5.10 w traffic , SPV C500
Mark, It's hard to really say. When you're on the move, signals are going to be fluctuating. In my tests I found probably on average a 2 sat difference, it really does depend on the current signal strength and where it's positioned in car.
iancjc
using the LP version with an external antenna on the roof of a people carrier, I went from 3/4 sats with 50% power without the external to 7/8 sats (8 is the max with the LP card) with 95% power (looking at the bars on tomtom's gps software).
Based on my (limited) experience I would recommend it. (it also sticks to the roof very well as I went through a car wash yesterday and forgot it was up there - to my surprise and relief it was still there when it had finished!).
mstockha
Thanks, based on what others have said it looks like I may get a satellite or two more (I do take into account that performance varies, the value of your lock may vary, investments may rise / fall / crash etc :-) )
I'll buy one now and let you all know how it goes.
Mark
Why me?
mstockha
OK, first impressions. Very small external antenna from Pretec, strong magnet, and very long cable.
I have positioned the ant on the windowsill of my office (onto the courtyard) and get an intermittent lock. Considering that the visible sky is postage stamp like, I cannot wait to try it in the car. As has been mentioned before, the connector into the side of the CompactGPS unit it a bit stiff, and will need care to ensure that it does not get bent. Tune in tomorrow for the next exciting installment (plus whether I can get the Arkon vent mount to fit my car)
Mark
Why me?
I think the main thing to worry about with the connector is constant abuse on the pull as to unplug it requires quite a bit of effort, and there isn't much of a plug to grab hold of.
mstockha
Yes, the plug to the external antenna could be an issue over time, I will just have to be careful.
I have used the kit in anger now, and am VERY impressed with the performance of the GPS with the external antenna attached. I have it atached to the top off the roll hoop on my convertible, and get a good 7 satellites regularly. All that now needs sorting is the cable run. 9/10, a great addition for £30ish.
Why me?
alix776
i can verify the constant use ive gone thorugh 2 cables in 6 months the plgs just seam to fall to bits but ive never had less than a 5 sat lock
device Lumia 950 xl
I prefer the newer MCX connection sockets/plugs, they're alot easier to plug in and unplug causing less ware and tare on the socket.
alix776
dave ill see you about them at the summit if thats ok
device Lumia 950 xl
