Trippytinker Occasional Visitor
Posted: Fri Mar 16, 2012 11:10 am Post subject: Tomtom Home temp files on drive C: |
I have my main hard-drive partitioned on my PC, C drive for system files and D drive for everything else.
In Tools/Home preferences I have everything set for drive D.
When updating the latest map however I get the message that there is not enough free space for temp files on drive C:\. please run disk cleanup.
Is there anything I can do other than create more space?
Thanks in advance |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Fri Mar 16, 2012 11:45 am Post subject: |
Why wouldn't you want to run a disk cleanup and get rid of all the junk on your C: drive. If your C: drive is pretty full, it will slow down your computer. Have you shifted your Windows swap file to your D drive? |
Posted: Fri Mar 16, 2012 12:15 pm Post subject: |
There's no reason or problem running disk clean-up in fact it's already done I was wondering why when I use drive D:\ for non-windows programs & downloads etc Home still steers towards drive C:\.
I'm OK as I have lots of space but on one of my kids computers they have a small SSD for their windows files and don't have the option of increasing their drive C's size . |
justbrowsing Frequent Visitor
Posted: Fri Mar 16, 2012 12:24 pm Post subject: |
In TTHome/Tools/Preferences/Folders you should be able to change where everything goes? |
Andy_P Pocket GPS Moderator
Posted: Sat Mar 17, 2012 8:08 pm Post subject: |
He's done that... see post #1.
AFAIK, Home only puts it's main downloads and backups etc. into the place you tell it to (eg a different drive).
Other stuff still gets put onto the C: drive in at least two places:
C:\Documents and Settings\username\Application Data\TomTom\HOME\Profiles\abcdefgh.default
and
C:\Documents and Settings\username\Local Settings\Application Data\TomTom\HOME3
Maybe if you change a setting or two somewhere in Windows itself you can steer the temp files elsewhere? _________________ "Settling in nicely" ;-) |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Mar 17, 2012 9:21 pm Post subject: |
There is an old DOS command that may work here:
![](http://i267.photobucket.com/albums/ii300/dhn1/untitled-5.jpg) _________________ David |
Posted: Sat Mar 17, 2012 10:29 pm Post subject: |
Google is your friend Try this |
Posted: Sun Mar 18, 2012 12:08 am Post subject: |
Thank you for the replies, reading the google link I think I understand what's happening.
I couldn't see why having located everything in the 'other' drive it needed to use C: but guess it's just a windows thing.
I's no real problem and I guess if I alter the location for the temp files it would apply for everything so it's far easier to make sure that I use good housekeeping on a regular basis.
many Thanks
Tinker |
Posted: Sun Mar 18, 2012 12:23 am Post subject: |
Just a thought. System Restore takes up quite a bit of space on the C: drive. You can adjust the amount of disk space it takes somewhere. Can't remember where, or be bothered at 11:22 at night to find out ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sun Mar 18, 2012 7:49 am Post subject: |
In XP it's Start - Programs - Accessories - System Tools - System Restore
In Win7 and, I believe, Vista, type rstrui into the Start Menu Search Box. You can also type restore into the Search Box _________________ Richard
Posted: Sun Mar 18, 2012 12:12 pm Post subject: |
Oldboy wrote: | In Win7 and, I believe, Vista, type rstrui into the Start Menu Search Box. You can also type restore into the Search Box | But I could not find where to set the amount of disk space used. It;s there somewhere, because I changed it on my desktop that I use a SSD as C:drice. I cloned a larger HDD onto the SSD and the SSD pretty soon flled up with restore points. Google was my friend and found This for Vista but there is also a link there to adjust it for W7 |
