Pocket GPS World :: View topic - Avoid Roadblock feature in CP5?
topgazza
PostPosted: Sat Aug 28, 2004 2:36 pm    Post subject: Avoid Roadblock feature in CP5? Reply with quote
Its mentioned in Dave's review but not detailed. Is notice that its a feature in TT3. How does this work on CP5 as I would find it one of the most valuable things to have ?
CrashBiker
PostPosted: Sun Aug 29, 2004 2:24 pm    Post subject: Reply with quote
Assuming I'm understanding the question appropriately, with an active gps signal cpl5 will let you call up the road list itinerary, select any road and pick avoid to get a route recalc without using the affected road.
If you are driving along and are suddenly warned of traffic problems ahead (via trafficmaster freeway for me, or road signs or radio) there is a main map button large enough to find with your finger to request an instant detour. Basically a request to leave the current route at the next available junction and reroute.
If I'm about to leave home/office and a traffic check lets me know the M3 is stuffed (for example) I use the first method to avoid the M3.
If I'm driving and trafficmaster freeway says 8 miles of stationary traffic after the next junction, I hit the detour button and get an instant reroute, with an indication of the extra distance of the detour. I can take the detour or I can hit the "un-detour" button, or I can just drive on and ignore it and will be routed back onto orignial route automatically.
Does this answer your question?
Crash
topgazza
PostPosted: Sun Aug 29, 2004 4:31 pm    Post subject: Reply with quote
Sure does, thank you. I also use Freeway and it has proved to be well worth the money. I like the idea of touching the screen to "eliminate" a road and I presume just turning off would also do the job, though not as specific as removing a particular road/junction from a route. Does it take you back to the next junction in this instance if you select a reroute or are you only allowed to de select a complete road?
Sorry to be pedantic but I am keen to understand the ease of use in practical uses, i.e. peoples own experiences. Its usually more valuable than reading the manual....
