Pocket GPS World :: View topic - Start2 - Avoid motorways function
reubs007
PostPosted: Mon Dec 26, 2011 8:50 pm    Post subject: Start2 - Avoid motorways function Reply with quote
Hi All
I bought my mum a Start2 last year, assuming it had the Avoid Motorways function. Turns out not!
Followed the instructions here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=87435&start=0&postdays=0&postorder=asc&highlight=
I tried all 3 versions of the text in tomtom.mnu suggested by kondor in the associated post. The problem is that the TomTom then boots straight to the options menu. There is no way to get out of the options menu & actually plan a route. It usually boots to a screen with 2 options: Plan Route & Browse Map.
Do you have an alternative text for tomtom.mnu I can try, or a whole different method?
I'm really disappointed with TomTom, my ancient one has this feature, I can't understand why they would remove it :-(
Thanks so much for your help!
Reubs
TomTom START
App 9.057.562242.2
Map UK & ROI v845.2645
PostPosted: Tue Dec 27, 2011 4:58 pm    Post subject: Re: Start2 - Avoid motorways function Reply with quote
TT made the mistake (as they see it) of having too many functions on the early models.
Their current thinking is that if EVERY model does everything, why would you ever buy one of their more expensive ones? So it kind of makes sense to leave off some features from the cheaper models.
BUT... what is infuriating is that they have NEVER produced a proper chart describing what each model can and cannot do.
They left the 'technical' descriptions to their marketing department to write and that's plain useless.
The best comparison chart I know of is here:
TTForums.com Click Here for the Reference Guide
"Settling in nicely" ;-)
reubs007
PostPosted: Tue Dec 27, 2011 6:45 pm    Post subject: Reply with quote
Hi Andy
Thanks for getting back to me! My goal is to add the avoid motorways option to the Start2 menu.
I've found that you can set up a folder called SDKRegistry & create a file called tomtom.mnu to modify the menu structure on the device and restore missing features.
The tomtom.mnu text in the post above doesn't work properly on my Start2 - you lose the Plan Route option.
I have found text here that restores the avoid motorways functionality.
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=136159
However, it leaves the interface a mess. I can use it to change planning preferences to avoid motorways, and then revert back to old menu structure by renaming SDKRegistry folder.
However, if I do this, then my mum would never be able to plan a motorway route. No good.
So does anyone have the right tomtom.mnu text for Start2 that would just add the avoid motorways option *without* changing the rest of the interface around?
Hope that all makes sense!!
Thanks!
Reuben
