hasiel Occasional Visitor
Posted: Thu Dec 01, 2011 7:36 pm Post subject: nuvi 1370t--installing map on micro SD newbie question |
So I purchased a microSd card, and used Garmin's MapInstall program, and installed only to the micro Sd----a map of Europe that MapInstall had me choose the boundaries for.
My microSD is inserted while I type this.
Under map info settings on the Nuvi device, it shows two maps showing with a green checkmark:
CN Europe NT 2012.30 (this is in black bold type)
(1)Sankt Polten, Osterrecih, Wien, Oster (this is greyed out)
(2)Western Europe
CN North America NT 2012.30 (this is in black bold type)
(1) US & Canada (this is greyed out)
and with the micro SD card removed, it shows:
(1)Western Europe (this is greyed out)
My questions are:
1. I have two Europe maps showing. Does Garmin device automatically select the right map when I am in Europe, or do I have to do something, like you do on a TomTom, to swap maps (switch from device to SD) ?
2. Why did the map that MapInstall and me created, come up with the name "Sankt Polten, Osterrecih, Wien, Oster", when I chose the boundaries of Western Europe including southern Italy, Portugal, and Scandinavia?
3. Why when I went to use MapInstall again, this time choosing North America to install to an microSD, it did not copy to the SD?
Only one map at a time works?
Thanks for your advice, in advance.
Terry
ps
If you can point me to some tutorials about this I would appreciate. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Thu Dec 01, 2011 8:10 pm Post subject: |
Basically the reason why maps appear 'greyed out' is that you can't change them, but if they're listed then they're installed.
Sankt Polten, Osterrecih, Wien, Oster is in Austria. Somehow you've just downloaded that map tile to the card, since that's all that disappears when you remove it.
You need do nothing to view the maps, you can prove this to yourself by zooming out until you can see the relevant maps, then zooming in again. |
Posted: Thu Dec 01, 2011 8:46 pm Post subject: More questions... |
sussamb wrote: | Basically the reason why maps appear 'greyed out' is that you can't change them, but if they're listed then they're installed.
Thanks sussamb,
Yes I was able to zoom in and out on Sankt Polten, how do I know though, whether or not the Garmin is using the microSD map European map or the one installed on the Garmin?
Can you copy more than one map onto the microSD? I tried and only one shows???
Thanks.. |
Posted: Thu Dec 01, 2011 11:13 pm Post subject: |
You can have more than one additional map on a SD card, but you'll have to rename them as you go along as MapInstall by default names them gmapsupp.img (I think), have a look and see. Otherwise the next map will overwrite the first, which is the reason you only see one map. |
Posted: Fri Dec 02, 2011 1:13 am Post subject: sorry to be a bother...but |
sussamb wrote: | You can have more than one additional map on a SD card, but you'll have to rename them as you go along as MapInstall by default names them gmapsupp.img (I think), have a look and see. Otherwise the next map will overwrite the first, which is the reason you only see one map. |
I renamed the gmapsupp.img file to gmapsuppremove.img, before installing a map of an Italian small town.
The new map of Italian small town doesnt show on the list in the Garmin device. Neither does the other map that is on the microSD.
Thanks again and again. Terry |
Posted: Fri Dec 02, 2011 8:36 am Post subject: |
Well they should work. Do you have them in the correct folder on the card? They should be in the root folder in a folder named Map, so something like I:\Map
Also just confirm the card is formatted to FAT32? |
Posted: Sat Dec 03, 2011 2:28 am Post subject: now no maps are showing on Device-Maps-info |
sussamb wrote: | Well they should work. Do you have them in the correct folder on the card? They should be in the root folder in a folder named Map, so something like I:\Map
card is formatted to FAT32, however, now no maps are showing on Device-Maps-info. Got a message when using MapInstall that there was an error, and asked if I wanted to report it to Garmin.
Hmmm? |
Posted: Sat Dec 03, 2011 10:00 am Post subject: |
Maybe card is faulty, worth trying another one?
All I can say if you've checked everything I've suggested, and used mapinstall correctly, it should work, it does on my 1490 ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Sat Dec 03, 2011 5:00 pm Post subject: One final question- formating microSD |
sussamb wrote: | Maybe card is faulty, worth trying another one?
In the format screen using Vista, one category says "allocation unit size"
should i be using the "default allocation size" or the other choice is how many bytes/kilobytes?
I think I chose "default allocation size" ??? |
Posted: Sat Dec 03, 2011 8:13 pm Post subject: |
AFAIK it should be the default.
Does your PC see the card when your nuvi is plugged in? |
Posted: Sat Dec 03, 2011 8:29 pm Post subject: |
sussamb wrote: | AFAIK it should be the default.
yes the PC sees the card, and i can view jpeg pics that I snapped on the Garmin device. |
Posted: Sat Dec 03, 2011 9:05 pm Post subject: |
Not sure I can help further. Unless someone else has a bright idea your next step is to call Garmin ... have your nuvi plugged into your PC and they can often sort things remotely, but be prepared for a bit of a wait ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Sat Dec 03, 2011 11:14 pm Post subject: Thanks for all your help |
sussamb wrote: | Not sure I can help further. Unless someone else has a bright idea your next step is to call Garmin ... have your nuvi plugged into your PC and they can often sort things remotely, but be prepared for a bit of a wait ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Just a final note to tell you what I have done, for the benefit of everyone.
I exchanged my MicroSD card for a new one and formatted to defaul fat32 on my Vista OS. I tried MapInstall again and it didnt work. I put some pics that I took back on to the MicroSD and was able to view them.
I then used Google to export a destination directly to the MicroSD card, and was able to view it on "Favorites" on the Garmin.
I then created a service request at Garmin, they will get back to me in three business days
If I was betting, I think the problem is with the MapInstall software.
Thanks, "sussamb" enjoy your weekend. |
Posted: Sun Dec 04, 2011 7:08 am Post subject: |
Let us know the outcome ... good luck with Garmin ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
willton Lifetime Member
Posted: Sun Dec 04, 2011 12:42 pm Post subject: |
i think that if you have e.g. the whole of europe 2012 and then also add a small part of that map, the map list will only show the greater map i.e. whole of europe.
the main 'default' map is named gmapprom.img and will be the prominent map other maps have to be in the right folder (device\.System or SDCard\Garmin\maps or something like that) and can be called "anything".img and stored on the SD or the device, space allowing.
I think you should format the card via the device rather than vista. |
