Pocket GPS World :: View topic - Wanted - SD card for Tom Tom ONE
Post new topic   Reply to topic    Pocket GPS World Forum Index -> For Sale / Wanted
PHILIP2908
PostPosted: Fri Nov 25, 2011 11:13 am    Post subject: Wanted - SD card for Tom Tom ONE Reply with quote
Hi all,
Managed to wreck all the directories on mine whilst trying to add some POIs. Now says 'no maps found'. Unit is OK as the card I have for the USA works fine.
Has anyone out there got one? Might consider a whole unit if the price is right.
Regards all,
Phil d'A
PostPosted: Fri Nov 25, 2011 3:23 pm    Post subject: Reply with quote
Do you have a back up of the device on your computer or have you ever updated a map using your computer? if so it should be possible to re-build the data required for the card - Mike
PHILIP2908
PostPosted: Fri Nov 25, 2011 3:44 pm    Post subject: SD Card for TT One Reply with quote
Thanks, tried that also but that was what became corrupted and messed up the root directories on the card.
Regards
Phil d'A
PostPosted: Fri Nov 25, 2011 3:56 pm    Post subject: Reply with quote
You can delete all the files in the root then connect to TomTom Home and use the update my go option, this will download a fresh set of files and put them in the various folders as well as the root, if it still states no maps found then your map folder must also be corupt - Mike
Post new topic   Reply to topic    Pocket GPS World Forum Index -> For Sale / Wanted All times are GMT + 1 Hour
