MarkH Occasional Visitor
Posted: Fri Aug 20, 2004 3:35 pm Post subject: Fortuna Clip-on - getting ST mode back after flashing? |
I knew I was meant to change the mode before flashing but I changed it to the wrong mode. It didn't help that the first page of the PDF instructions keep disappearing because it requires Chinese language installation.
Has anybody a flash image for flashing the ST chip back to the way is was. I can't seem to get a fix in ST or XT mode. |
czachari Occasional Visitor
Posted: Sat Aug 21, 2004 7:17 pm Post subject: You need to set the GPS in "boot mode" |
Unfortunately, no one has been kind enough to shed some light into how to accomplish that, not even fortuna tech support.
CZ |
Posted: Sun Aug 22, 2004 5:31 pm Post subject: |
My device still works but I'm getting quite a bit of lag - it's around 50m behind when I'm walking in both ST and XT modes. |
Posted: Mon Aug 23, 2004 10:53 am Post subject: |
I've got an ST firmware off Fortuna this morning. I've put it on my server:
http://www.markhorgan.com/store/STfirmware.zip
Put the device in ST mode before you flash the ST firmware and follow the same procedure as flashing the XT firmware. I've just flashed mine ok, I will try out the receiver sometime later to see if it works any better. |
Posted: Mon Aug 23, 2004 7:49 pm Post subject: |
ST mode seems to work again. Tried XT mode, the first time I was getting lots of lag and 'sticking' but the second time it seemed to work ok. At least my receiver is usable again. ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
jlw Frequent Visitor
![](http://blodsugare.se/avatar/pocketgpsworld.jpg)
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Tue Aug 24, 2004 4:13 pm Post subject: |
where do i downloadthe flash software again? _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case |
