Vernon Occasional Visitor
Joined: May 30, 2004 Posts: 22 Location: Cambridgeshire
Posted: Sun Aug 22, 2004 12:15 pm Post subject: Still just want it to work with sound |
After successfully (thanks to the Forum) getting TTN III to locate a signal and to plan some test routes, I now get ready for the first drive out to discover no voice guidance. Checked the sound settings on the TomTom - all correct, all ticked, volume at max. Checked the XDAII pocket PC. Sound systems working on that - played some music and recorded a voice memo to make sure. Clicked on the 'test' button on The TomTom properties screen and still met with silence. Sound yesterday and dumbness today Please don't tell me I have to do a hard reset and try all over again? Thanks in advance for any advice. _________________ Elderly Vern |
ali Occasional Visitor
Posted: Sun Aug 22, 2004 12:44 pm Post subject: |
A soft reset may be enough to cure your problem it seems to fix a lot of little quirks. |
Posted: Sun Aug 22, 2004 12:50 pm Post subject: |
Thanks Ali - tried several soft resets, still no-go. _________________ Elderly Vern |
alix776 Pocket GPS Moderator
Posted: Sun Aug 22, 2004 5:19 pm Post subject: |
did you add the voice files when you installed the software to the xda try changeing the voice prompts if that doesnt work then if it was me id reinstall the the software after unistalling it using activesync or the remove programs on the ppc
just as a side thought to test if the voice files are there start tt3 up then go to properties on the fisrt screen you will see a check box for voice instructions make sure that is checked theres a slide control move that to the righthand side of the xda then press the test button on the screen you should hear a voice instruction other or you could use file explorer to see if their there if not as above im afraid its a reinstall _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
copthorneking Occasional Visitor
Posted: Wed Aug 25, 2004 3:19 pm Post subject: |
I had this too and it drove me MAD!
Try going to Start\settings\sounds & reminders\ Enable sounds for programs.
This sorted it out for me.
Let us know if it works for you too, |
Posted: Wed Aug 25, 2004 3:47 pm Post subject: |
Many thanks to alix776 and to copthorneking.
I tried absolutely everything. The best solution was to admit defeat and to send, in my case, the whole lot including my XDA II to Global Positioning Systems whom I bought the TomTom system from. They have been VERY helpful and concerned. Going to recommend them to all, if it comes back working! _________________ Elderly Vern |
