Pocket GPS World :: View topic - New User with Garmin w205 Cam alert not working
elia2002
PostPosted: Sat Sep 24, 2011 7:23 pm    Post subject: New User with Garmin w205 Cam alert not working Reply with quote
Cam alert has never worked and I have been trying for over a week now.
I have followed the download instructions.
Garmin 205 satnav says alerts downloaded but does not work.
Loaded to sd card but still does not work.
Have also got Garmin's latest POI loader update.
can any one help please.
Eliia
dales
PostPosted: Sun Sep 25, 2011 5:22 pm    Post subject: Reply with quote
You might find this post helps.
If the file on your SD card is a .poi file, try renaming the extension to .gpi
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
PostPosted: Sun Sep 25, 2011 7:15 pm    Post subject: Reply with quote
elia2002 can you let us know if this is the cause and if it resolves your issue.
We're in contact with Garmin regarding this, but the more evidence we can provide, the better.
elia2002
PostPosted: Tue Sep 27, 2011 5:26 pm    Post subject: new user Garmin 205w Reply with quote
Thank you to all of you who have tried to help me with the loading problem.
I thought I had got it to load successfully but the road test was negative.
This was the 4th negative road test and I am getting pretty despondent now.
I have followed the advice to the best of my abililty.
Any more ideas please.
Elia
PostPosted: Tue Sep 27, 2011 7:11 pm    Post subject: Reply with quote
Can you tell us what you have tried so far? Have you checked for the .poi / .gpi file issue?
PostPosted: Tue Sep 27, 2011 9:35 pm    Post subject: Reply with quote
Would it be worth trying the previous version of POILoader, given all the issues with v2.7?
I've uploaded POILoader v2.6 here.
PostPosted: Tue Sep 27, 2011 10:04 pm    Post subject: Reply with quote
If you go to Where To / Extras / Custom POI do the cameras show up in the list there? This will check to see if the POIs have been transferred or not.
If so then have you gone into Setting (Tools?) Proximity Alerts and made sure the Custom POI box is ticked? I.e. without this then you wil not get any alerts even if the files are on the device.
And, finally, how are you doing your road test? Garmin devices don't show the icon / alert if you are going 'too slow' you need to be close to the set speed of the POI/camera location.
elia2002
PostPosted: Thu Sep 29, 2011 11:37 pm    Post subject: 205w loading probs. Reply with quote
Hello again
Thanks to all of you who have helped with this issue.
I think I have followed the advice so far and will keep trying and will attempt to describe what I have done in more detail if the next attempt fails.
I have tried a road test today after attempting to adopt the earlier advice with no success.
However I have loaded the earlier version of PIOLoader as suggested. Will road test tomorrow. It is showing as having loaded.
I will report what happens ASAP after that.
I shall continue with trying to get this to work and I am really grateful for all the helpers and their patience and advice.
Thanks again for your help so far and so patiently bearing with my difficulties.
Elia
PostPosted: Thu Sep 29, 2011 11:41 pm    Post subject: Re: 205w loading probs. Reply with quote
Then why don't you answer their direct questions? Shocked
elia2002
PostPosted: Fri Sep 30, 2011 7:47 pm    Post subject: Success at last!!!!! Reply with quote
Thanks to all.
Reverting to v2.6 download and replacing the latest version has worked.
That was all that was needed. v2.6 and CamerAlert is a much happier combination.
Sorry if I caused some frustration to some of you who were trying to help but whatever I did with v2.7 things were just not working.
Thanks again, I would not have succeeded without your advice.
Elia Smile
PostPosted: Fri Sep 30, 2011 9:40 pm    Post subject: Reply with quote
It's all sorted which is the main thing. You'll appreciate that, for us, it's frustrating that the issue is caused by buggy Garmin software which is outside of our control but that's our issue not yours.
I'm delighted that you persevered as our data is much better than the service offered by Garmin as many here will attest, and that is after all the most important bit!
