Pocket GPS World :: View topic - Button problem
Button problem
spudh
PostPosted: Tue Aug 16, 2011 10:48 pm    Post subject: Button problem Reply with quote
One of our Active 10's has come back from 2 months of hardship in the field with the bottom left button not working (the one to select Map). I've taken the thing apart and traced the problem to the actual microswitch, I can get it to work by jumping the button contacts.
In our work in the field you really need the map button as you have to record the coordinates all the time so its the button pressed most. Now, I can kinda get round it by changing the setup from right handed to left handed but then I've no way of swapping through the pages without disassembling it, so I'm in a bit of a bind.
Anyone know if there are any key short cuts or anyway I can reconfigure the buttons that I can use any other button to select either menu or map without the bottom left button?
ChrisJakarta
PostPosted: Wed Aug 17, 2011 3:01 am    Post subject: Re: Button problem Reply with quote
I'd suspect the shortest shortcut would be to send it back to SatMap for a General Service. They'll return it like new, and if you ask kindly, my experience is that you'll get it back in a couple of days.
Chris
22.055 (29 May 24)
