Pocket GPS World :: View topic - Garmin nuvi 250 - Entering coordinates
arkiboys
PostPosted: Sat Jul 23, 2011 9:58 am    Post subject: Garmin nuvi 250 - Entering coordinates Reply with quote
How do I enter the GPS Coordinates i.e.
45.531650, 12.722425 (lat/long), +45 degree 31' 53.94", +12degree 43' 20.73"
Thank you
PostPosted: Sat Jul 23, 2011 12:57 pm    Post subject: Reply with quote
Here's a link to the Nuvi 200 Series Owners manual
Page 10 shows the procedure.
Basically its: Where to... / Coordinates, and the 'Format' button should allow you to change between decimal degrees (DDD.dddd), Degrees, minutes seconds (DDD,MM,SS) or Degrees, minutes and decimal minutes (DD.MM.mmmm)
If your coordinates are written using N,S,E,W before the numbers, you may need to replace S or W with a minus sign instead and just ignore N and E (so for example, N51.12345, W0.67890 would be entered as 51.12345, -0.67890). That's how Google maps shows coordinates, it just depends what formats the Nuvi can use.
However, that manual covers the whole range of models in that series and some may have less or more features than others.
So if you don't see those menus on your model then it won't be possible to enter coordinates (some of the cheaper TomTom models are crippled in this way)
Hope it works for you with the 250....
"Settling in nicely" ;-)
arkiboys
PostPosted: Sat Jul 23, 2011 8:20 pm    Post subject: coordinates Reply with quote
Can you please guide me how to enter this coordinate into my 250 nuvi coordinates as destination?
Thank you
PostPosted: Sat Jul 23, 2011 8:29 pm    Post subject: Reply with quote
From the start up screen hit the "Where To" then scroll down to "Coordinates" if the format isn't what you want hit the option to change this parameter (the three horizontal bars top left) followed by "Format" then enter the Lat/ Long values - Mike
arkiboys
PostPosted: Sat Jul 23, 2011 9:35 pm    Post subject: Reply with quote
I can get to the coordinates but not sure which format to chhoose and which numbers to enter.
Can you guide me based on the initial figures I sent please?
PostPosted: Sun Jul 24, 2011 11:17 am    Post subject: Reply with quote
From the format option make sure h ddd.ddddd is selected (Decimal Degrees) - Mike
PostPosted: Sun Jul 24, 2011 4:46 pm    Post subject: Reply with quote
... and then enter the FIRST TWO numbers you quoted (which are in "decimal degrees format).
The second pair are the same location using the "Degrees, minutes, seconds" format.
arkiboys
PostPosted: Sun Jul 24, 2011 8:40 pm    Post subject: Reply with quote
selected the format as :
h ddd.ddddd
And then entered:
N 45.531650
W 12.722425
Is that right?
THank you
PostPosted: Mon Jul 25, 2011 8:23 am    Post subject: Reply with quote
Yes that is correct - Mike
arkiboys
PostPosted: Mon Jul 25, 2011 9:32 am    Post subject: Reply with quote
The sat nav says it does not find this location.
Anita
PostPosted: Mon Jul 25, 2011 9:59 am    Post subject: Reply with quote
The location appears to be Viale Oriente, 30016 Jesolo VE, Italy.
Do you need to select the correct country before entering the coordinates?
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Mon Jul 25, 2011 12:09 pm    Post subject: Reply with quote
Looks like a nice beach holiday Smile
arkiboys
PostPosted: Mon Jul 25, 2011 1:38 pm    Post subject: Reply with quote
I have selected the country.
It says :
Can not calculate route. No route near destination.
Any thoughts please?
arkiboys
PostPosted: Mon Jul 25, 2011 2:21 pm    Post subject: Reply with quote
I have found the locations.
It should be N and E. Initially I was doing, N and W
PostPosted: Mon Jul 25, 2011 3:12 pm    Post subject: Reply with quote
Yep, that would make a difference Very Happy
