Pocket GPS World :: View topic - Speed limit symbol
Speed limit symbol
Maddon
PostPosted: Fri May 27, 2011 5:01 pm    Post subject: Speed limit symbol Reply with quote
I have just purchased the Garmin 1490t and am very happy with it. One thing I have noticed is that the speed limit symbol( bottom right of screen )is incorrect on some roads. Is there a way of changing this or is this a map issue?
Maddon
PostPosted: Fri May 27, 2011 5:49 pm    Post subject: Reply with quote
If the device is miss reporting the speed limit then its down to inaccurate data within the map, I am not aware of a way to change this on the device, are you running the latest map? - Mike
Maddon
PostPosted: Fri May 27, 2011 5:59 pm    Post subject: Reply with quote
Hi mikealder
Actually I registered yesterday and there is a map update waiting so I will give it a go. Just thought that there was a way to manually change it but did think it may be hard coded.
maddon
PostPosted: Fri May 27, 2011 9:34 pm    Post subject: Reply with quote
While it doesn't help your existing map, you can report road speed changes directly to Navteq here: http://mapreporter.navteq.com
It might take a while to eventually end up in the map data itself but at least you'll have done your bit!
