Pocket GPS World :: View topic - App losing settings and database
darrengsaw
PostPosted: Sat Jan 22, 2011 2:11 pm    Post subject: App losing settings and database Reply with quote
Hi there,
I seem to be having trouble with the app reverting to default settings and the demo database. it does still retain my account though.
I did have the test version installed, but I deleted this before installing the current version from the market.
Any help appreciated.[/i]
PostPosted: Sat Jan 22, 2011 2:23 pm    Post subject: Reply with quote
What handset model? Is there anything unusual about your device, custom OS? Apps2Sd etc?
darrengsaw
PostPosted: Sat Jan 22, 2011 8:22 pm    Post subject: Reply with quote
Handset is samsung galaxy s.
It is running stock froyo 2.2.1, not rooted.
I've tried it in phone memory and sd, doesn't seem to make a difference.
Works perfectly apart from this.
Thanks for your help.
PostPosted: Sat Jan 22, 2011 8:32 pm    Post subject: Reply with quote
It's the first issue of this type reported. Have you tried exiting the app and re-launching (ore re-booting)?
Failing that, can you send us the log-files, found in:
sdcard\Android\data\com.pocketgpsworld.cameralert\files
.zip them up and send to support[at]pocketgpsworld.com
PostPosted: Sat Jan 22, 2011 9:56 pm    Post subject: Reply with quote
Also, on your device, can you please check how much main memory you have left? It is possible that the database update fails because there isn't enough space.
darrengsaw
PostPosted: Sun Jan 23, 2011 12:55 am    Post subject: Reply with quote
Hello again,
1.66 gb free in main memory plus 5.7gb on internal sd.
I've emailed the logs over to support as well now.
darrengsaw
PostPosted: Sun Jan 23, 2011 7:16 pm    Post subject: Reply with quote
Some more info:
I uninstalled the current version and reinstalled the 3.33 test version, this worked flawlessly when first installed, but now behaves the same as the current market version 3.46.
I remember now that when I first installed the current version it did return a ' not signed correctly' error. the test version was installed at the time. Once I un installed the 3.33 version the 3.46 version then installed successfully.
It also retained the link to my account, I wonder if it were possible to completely clean the data and re link my account whether this may fix the problem.
Hope the extra info may help.
PostPosted: Sun Jan 23, 2011 7:22 pm    Post subject: Reply with quote
That is expected.
That would not have any effect. Our server retains your device ID, so an uninstall/re-install would have the same ID and hence no necessity to re-link each time.
It has no other purpose than controlling access to the database - it could not cause the issue you describe.
PostPosted: Sun Jan 23, 2011 9:09 pm    Post subject: Reply with quote
@darrengsaw: Looks like you may have inadvertedly pressed the Download button twice in quick succession. Or maybe your touchscreen is just out of whack (I see that quite often on my Nexus One, and the only "fix" is to put the device to sleep and wake it up again. That seems to recalibrate the touchscreen). Give it another try.
darrengsaw
PostPosted: Sat Jan 29, 2011 12:17 pm    Post subject: Reply with quote
Fixed, a simple hard reset of the phone has got everything working as it should again.
