djc1610 Regular Visitor
Joined: Nov 18, 2005 Posts: 186 Location: St Neots, UK
Posted: Tue Jan 04, 2011 1:28 pm Post subject: Lost POIs Garmin Nulink 1695 (PoiLoader) |
I have a directory on my laptop named Garmin POIs which contains two folders named FloridaHoliday2011 and MyPois.
The two folders contain Garmin compatible POIs in csv format and the associated bmp files. The POIs are all read correctly in PoiEdit as Garmin csv POIs.
I then used the PoiLoader to transfer these to the Garmin. In the POI folder I find a new file called poi.gpi which I renamed to MyPOIs.
After safely disconnecting the Garmin from the laptop I switch it on and select GoTo Points of Interest. There is a list of POI categories but I cannot find the ones I have just added.
The Florida POIs are naturally all a long distance from where I am now but many of the others are quite local.
Why cannot I see them and what have I done wrong? _________________ David
VW RNS 510 and TomTom 5200 World |
Posted: Tue Jan 04, 2011 6:00 pm Post subject: |
You will find the under Custom POIs if loaded correctly.
How many POIs did POILoader report it had loaded? |
Posted: Tue Jan 04, 2011 6:07 pm Post subject: |
Reading the manual it looks like the procedure is
Where to?
Extras |
Posted: Sat Jan 08, 2011 12:45 am Post subject: |
PaulB2005 wrote: | Reading the manual it looks like the procedure is
Where to?always
Extras |
Your quite correct. This is what I have been doing.
I am new to garmin, quite old and relying on my mrmory is not always a good idea, _________________ David
Posted: Mon Jan 10, 2011 11:00 pm Post subject: |
I am now in Longboat Key, Florida and I am sitting in a superb appartment overlooking a wild(ish) expanse of inlets covered in a wide range of birds. The weather is good and everything should be fine.
The downside........I have an upper respiratory infection leaving me with bunged up ears, sore throat and some considerable pain. It should be better just as I come home!
Whilst having little to do but endlessly trying to find one of the 5000 TV stations even remotely worth watching, read books, eat or sleep I decided to give the 1695 a thorogh going over and I found my "lost" POIs.
Where...under "Points of Interest".... Nooooooo
It'so logical
"Where To?" ... "Extras" ... "Custom POIs"
Obvious all the time! _________________ David
