Pocket GPS World :: View topic - MM2004 with BT308
MM2004 with BT308
White_Fox
PostPosted: Thu Jun 10, 2004 9:12 pm    Post subject: MM2004 with BT308 Reply with quote
Assistance/advice required
Hardware Ipaq HP1940
Globalsat BT308
Runs fine on TT3 but on MM2004 cannot communicate with BT308
I set up the 1940 to communicate with the BT correctly
On the MM2004 GPS set-up, I only see COM ports 1, 2, 3, & 9
I have tried all combinations with no success
I think the BT308 uses port 5 and/or 8 for its Bluetooth connection
How can I get round this
What speed should I be selecting
Also the BT308 uses SiRF, should I be selecting this type or the NMEA
I have searched the forum for similar probs but couldn't find anything.
Can someone help please
PostPosted: Thu Jun 10, 2004 9:28 pm    Post subject: Reply with quote
This is the old issue! Every TT GPS driver since v2.08 blocks the BT Com Port preventing any 3rd party apps from accessing it.
The solution is to either remove the 'TomTom~GPS' entry and soft reset or uninstall your GPS driver and install v2.07 available here.
White_Fox
PostPosted: Thu Jun 10, 2004 10:11 pm    Post subject: Reply with quote
Thanks Darren
being a newbie I didn't realise this was an old chestnut
Have added Chippenham Wilshire to my profile
Arne
PostPosted: Thu Jun 10, 2004 10:25 pm    Post subject: Reply with quote
No problem, I didn't intend to sound condescending, it's just that it's an issue that has driven us all mad. Many of us have other GPS apps as well and need access to the BT Port but this is a problem TomTom don't appear to recognise! At least the solution once you know it is simple to implement.
Welcome to the forums anyway, always happy to help no matter what the question Thumbs Up
dolced
PostPosted: Wed Aug 04, 2004 2:10 pm    Post subject: help help!! Reply with quote
I have bt308 and after two hours the green light is always on and it doesn't connect any satellites.... please please help me!!!
PostPosted: Wed Aug 04, 2004 3:32 pm    Post subject: Reply with quote
Have you bonded it with your PocketPC? Also what GPS applications do you have installed?
dolced
PostPosted: Thu Aug 05, 2004 9:34 am    Post subject: Reply with quote
Of Course!! I have a Toshiba e800; the application is GPS INFO and tom tom III is the navigation program. The bluetooth connection is ok (blue led on more speedy) thank you.
