Pocket GPS World :: View topic - Failed Map Update in TT Go 920 - Help Please
Fraserp
PostPosted: Mon Nov 22, 2010 6:55 am    Post subject: Failed Map Update in TT Go 920 - Help Please Reply with quote
Updated my 920 map, no apparent issues during the update.
After the update I could connect via TTHome and could use maps.
When I disconnected the device it remains in a on \off cycle using the start up screen then blank but never completes.
Only option has been to press the reset button.
Even then it does not switch on correctly, goes into the non\off cycle.
When cradled and the power on button switched it does come on and go into TTHome and I can access the device.
Any suggestion or ideas about what options I have?
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
PostPosted: Mon Nov 22, 2010 8:12 am    Post subject: Reply with quote
Try changing a favourite using Home, if that fails connect to the PC and use Windows Explorer to remove the MapSettings.cfg file from the Western_Europe map folder - Mike
Fraserp
PostPosted: Mon Nov 22, 2010 1:12 pm    Post subject: Reply with quote
I think we have resorvled this.
I reconnected the 920 via the cradle, and as suggested removed the mapsettings.cfg file. A restart and the device then prompted for all initial settings,:- country, time etc.....
I then copied back my saved mapsettings file.
It allowed a simple route to be planned and I disconnected it from TTHome.
I can now access the device without issues.
Thank you
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
22.054 (22 May 24)
