G4GVB Regular Visitor
Posted: Sun Nov 21, 2010 5:17 pm Post subject: GO 720 at the end of the road |
Hi all
Looks like my 720 has reached the end of the road. What is the later equal, I don't really want to by new. - Thanks _________________ GO 750 LIVE v9.430 - v8.753612 EU map
XL 350 MT v9.151 - v8.75366 US Map |
Posted: Sun Nov 21, 2010 7:37 pm Post subject: |
Whats up with your current device if all it needs is a new battery I would consider changing it for a new cell, the 720 is still a very capable device unless something other than the battery has failed - Mike |
Posted: Sun Nov 21, 2010 7:54 pm Post subject: |
I agree Mike a nice little box. Its not the battery. It works OK for anything from 5 mins to an hour then it locks up, nothing works, it then resets itself and I get the yellow line. It may then work for a while or it may come on and say here I am then lock again and it will keep repeating the cycle. I have tryed the flash tool, reinstalling the app, upgrading to the latest app, using the reset, thumping it, talking to it, but nothing will make it work when its in fault mode or crash when its in working mode. So unless you have any thoughts, and I know your very good at this stuff it may be time for an upgrade. _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Calomax Lifetime Member
Posted: Sun Nov 21, 2010 8:01 pm Post subject: |
The internal drive could be failing. It could be worth copying everything to an HDSD card, or loading it with a backup of the app and the map(s). That could well get it going again and save you the cost of a new, inferior, device. _________________ TT Go Essential |
Darren Frequent Visitor
Posted: Sun Nov 21, 2010 8:15 pm Post subject: |
Agree with Calomax, it is possible that the internal flash memory is dying. Using a memory card instead means the device will run off the memory card and bypass the internal flash.
That could be the solution. Memory cards are cheap and all you need do is buy one of sufficient capacity and then copy the internal memory contents to it or restore a backup (which you should take now if you don't have one!). _________________ Darren Griffin |
Posted: Sun Nov 21, 2010 8:35 pm Post subject: |
Thanks guys. I have a 2Gb card and am now copying the backup to it. How do I make the 720 boot from the card rather than the internal drive? _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Posted: Sun Nov 21, 2010 8:50 pm Post subject: |
G4GVB wrote: | How do I make the 720 boot from the card rather than the internal drive? |
It will default to memory card IF there is a valid operating system on it. _________________ Darren Griffin |
Andy_P Pocket GPS Moderator
Posted: Sun Nov 21, 2010 11:47 pm Post subject: |
That's exactly what happened to my 720 and I've continued using it with everything moved onto a memory card for years. |
Posted: Mon Nov 22, 2010 7:24 am Post subject: |
Its working now on the card. I will give it a try this week and see whats what. Thanks for all your inpur guy. _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Posted: Mon Nov 29, 2010 1:53 pm Post subject: |
Been using for a week now - no problems at all - Jobs a gooden - Thanks _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Posted: Sun Dec 12, 2010 9:15 pm Post subject: |
I spoke toooooo soon. Today it worked fine for an hour. Then locked up, reset itself, rebooted (Yellow line) put my position on screen then instantly locked up again. This went on over and over again. I have everything running on the SD card, even tryed running back on the internal drive. - No use - Don't know what to do next, except bin it. _________________ GO 750 LIVE v9.430 - v8.753612 EU map
