Pocket GPS World :: View topic - Remove NAG screen,,,,
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
jlw
PostPosted: Wed Jul 28, 2004 12:32 am    Post subject: Remove NAG screen,,,, Reply with quote
Is it possible to remove the enoying nag screen that pop ups while starting destinator 3?
I hate it!
Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case
TMF
PostPosted: Wed Jul 28, 2004 12:41 am    Post subject: Reply with quote
I hate it as well, just a waste of time. Once would be enough!
HP 2210
Destinator 3
Leadtek 9537
512MB CF
512MB SD
PostPosted: Wed Jul 28, 2004 7:01 am    Post subject: Reply with quote
Unfortunately not, most of the applications have this, although some are a little more user friendly and allow you to tick a box to tell it to go away from now on.
lbendlin
PostPosted: Wed Aug 18, 2004 5:49 pm    Post subject: Reply with quote
There are some news in this area. A german guy has programmed a little applet that you need to put into the destinator directory and start instead of Destinator. It will auto-answer the nag screen and the quitting confirmation request.
http://www.koolplaya.de/desti/DestiRobot/
Lutz
TomTom/TeleAtlas NAVTEQ
peeved
PostPosted: Tue Aug 24, 2004 12:37 pm    Post subject: Reply with quote
Lutz
How does one get the applet to to show in the Start Menu please? I have put it into the destinator directory but cannot get it to show in the program menu or start menu. Destinator does but not the destirobot.exe
Paul
lbendlin
PostPosted: Tue Aug 24, 2004 1:40 pm    Post subject: Reply with quote
in file explorer, navigate to \destinatorapps\destinator.
tap and hold destirobot.exe.
tap on copy.
then change directory to \windows\startup\programs (or wherever you want the shortcut to be)
tap on edit > paste shortcut.
Optionally rename the shortcut, and remove the shortcut to Destinator.
Lutz
peeved
PostPosted: Tue Aug 24, 2004 2:46 pm    Post subject: Reply with quote
Thank you very much, I was putting it into the wrong folder in Windows!
Paul
lbendlin
PostPosted: Tue Aug 24, 2004 3:49 pm    Post subject: Reply with quote
oops, there's a typo in my post.
should read \windows\start menu\programs.
Lutz
GPSinC3
PostPosted: Wed Aug 25, 2004 10:24 pm    Post subject: Reply with quote
Thanks to whoever wrote this, neat piece of code which works well. Assign it to a button and its a one push start to Destinator :D :D :D
djhonline
PostPosted: Sun Sep 05, 2004 3:46 pm    Post subject: Reply with quote
Though it does kick you straight out when you go to close - before you can answer "Are you sure you want to quit Destinator" which I miss!
lbendlin
PostPosted: Sun Sep 05, 2004 5:34 pm    Post subject: Reply with quote
Two versions of the program are available - the old version will not auto-answer the closing question
Lutz
Sso
PostPosted: Wed Nov 17, 2004 3:11 pm    Post subject: Reply with quote
Tested both versions and they worked fine, but next time I tried to start destinator I got a popup saying "Unregistered version of Destinator, do you want to register?" with Yes/no-buttons. Do I just need to enter the regcode again or do I have a serious problem?
/Stefan
lbendlin
PostPosted: Wed Nov 17, 2004 3:33 pm    Post subject: Reply with quote
should not be anything serious - try entering the code again.
Lutz
Sso
PostPosted: Tue Nov 23, 2004 1:46 pm    Post subject: Reply with quote
Unfortunatly it seems that I have a bigger issue.
Looks like my deviceID has changed, because it isn't the same as on my registered activation at Destinators website.
Do I need to use "Move licence to a different device" to get it to work?
Thanks for your help!
/Stefan
lbendlin
PostPosted: Tue Nov 23, 2004 3:18 pm    Post subject: Reply with quote
Your device ID has changed? is it a Toshiba?
Yes,transferring the license should fix the issue.
Lutz
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
22.062 (12 Jun 24)
