Pocket GPS World :: View topic - Kenwood DNX78220BT POI’s & speed cams
T3007
PostPosted: Fri Jun 18, 2010 9:39 am    Post subject: Kenwood DNX78220BT POI’s & speed cams Reply with quote
I have a Kenwood DNX78220BT. My problem is that when I update the SD card with either speed cams or POI’s on the existing POI file, it does not have the old details?
For example:-
My SD card contains (and working) speed cams files. I get a new batch of POI’s and use the Garmin POI loader. I choose, ‘Install New Custom POI’s’ and get the OK message. When I check the file it has removed the previous ‘speed cam’ details and now only holds the newly uploaded ‘POI’s’
Any help is greatly appreciated?
Regards
T3007
PaulB2005
PostPosted: Fri Jun 18, 2010 9:50 am    Post subject: Reply with quote
Hi and welcome.
You have to install ALL the POIs and Speed Cams EACH time. Not just the new ones. Keep a folder for the POIs and Speed Cams on your PC and then update as necessary. Each time load ALL the POIs and Speed Cams to the unit.
Moved to Factory-Fit and In-Dash SatNav Systems Forum from Membership Sign Up Problems.
T3007
PostPosted: Sat Jun 26, 2010 12:02 pm    Post subject: Reply with quote
Hi Paul,
Thanks for your help. I placed both speed cams & POI's csv's etc into one single folder from thier retrospective zip files & after uploading to the SD card via GarminPOI loader & then onto the 8220BT it works:)
Howver, i can see the bitmap for POI's, i only get grey 'dots' for the speed cams?
Thanks again for you help
KR
T3 Cool Cool 7
PaulB2005
PostPosted: Sat Jun 26, 2010 12:18 pm    Post subject: Reply with quote
Grey dots are caused by 2 things.
1 - More than 255 categories installed - i.e. you have too many POIs installed.
2 - The icons are missing or do not have EXACTLY matching names. Check your upload folder and make sure each Speed Camera file (CSV) has a BMP file with EXACTLY the same name.
T3007
PostPosted: Wed Jun 30, 2010 10:20 am    Post subject: Reply with quote
Hi Paul,
You have worked your maig again Laughing All icons appearing.
Now, how can we win ££££££££ on the lottery ? Laughing
cheers & c u in Miami Laughing
KR
T3 Cool Cool 7
PaulB2005
PostPosted: Wed Jun 30, 2010 10:24 am    Post subject: Reply with quote
Tell me what the solution was (it might help others) and i'll tell you a guarenteed way to win the jackpot on Saturdays National Lottery. Wink
T3007
PostPosted: Wed Jun 30, 2010 10:30 am    Post subject: Reply with quote
I took your advise & reduced the number of POI's . Starting with a few, checked they worked & increased,,,finally got all POI's & cams with icons Very Happy
As for the lottery, if your 'cunning' advise is to put every variation of numbers , then ??
C ya
T3007
PaulB2005
PostPosted: Wed Jun 30, 2010 10:35 am    Post subject: Reply with quote
Thanks.
To win the lottery buy a ticket befoe the draw but make sure the numbers you select are the same as the ones they draw on Saturday night. Might take a couple of goes to work but i have heard some people have had success.... Remember me when you win... Cool
T3007
PostPosted: Wed Jun 30, 2010 8:13 pm    Post subject: Reply with quote
ha, ha..
I'll remember..
TC
T3 Cool Cool 7
22.055 (29 May 24)
