Pocket GPS World :: View topic - Nuvi 3790 won't let me have pocketgps cameras
HellFire
PostPosted: Fri Jun 11, 2010 9:09 pm    Post subject: Nuvi 3790 won't let me have pocketgps cameras Reply with quote
Does anyone know why my nuvi 3790 won't let me select the pocketgps cameras, when I select custom POI it gets ticked, but when I select ok the alert screen goes back and I can see the custom POI gets unselected and the Garmin cameras become selected.
PaulB2005
PostPosted: Fri Jun 11, 2010 9:16 pm    Post subject: Reply with quote
The last couple of Nuvis i had (760 & 765) the screen couple be very inaccurate. Have you tried using a stylus or a biro with the cap on to make sure the presses are accurate??
The 765 was especially bad (or good depending on how you look at it) at selecting something other than the item i'd intended to press.
Finally use WebUpdater to make sure you have the latest firmware installed...
HellFire
PostPosted: Fri Jun 11, 2010 9:57 pm    Post subject: Reply with quote
Thanks for the fast reply, but this has a capacitive screen so I can only use a finger.t The screen does seem accurate as even selecting gps info from main screen is easy and that's a small icon, and yes I have the latest software.
BAVC10
PostPosted: Sat Jun 12, 2010 12:18 am    Post subject: Reply with quote
HellFire
I have just uploaded via PoiLoader and they seem to be there - will try on a route tomorrow.
Just tried the Voice Command - Fantastic!
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
HellFire
PostPosted: Sat Jun 12, 2010 4:45 am    Post subject: Reply with quote
I deleted the Garmin cameras so now I can select the pocketgps ones, they now show on the map, but when I approached them I get no warning, I even tried with ogg files as the 3790 has an ogg decoder. BAVC10 have you still got the Garmin cameras, as with me the pocketgps got deselected when I still had Garmin's there.
Yes the speech recognition is perfect, I can't fault it.
BAVC10
PostPosted: Sat Jun 12, 2010 8:02 am    Post subject: Reply with quote
Hellfire
I have both loaded and showing as ticked on my 3790. I will check today as I only loaded the PGPSW cameras once I had done a back-up of the Nuvi
HellFire
PostPosted: Sat Jun 12, 2010 8:36 am    Post subject: Reply with quote
Got the cameras, with custom cameras you have to be driving a route, they won't work with a simulation or just driving, with my 865 they would work anytime. I had to use WAV, as for some reason ogg wouldn't import, the file size of the POI was the same with and without ogg.
But under settings-system-about it mentions this product has Ogg Vorbis decoder.
If you have them both ticked won't you get duplicate warnings.
Edit: With no routes plotted you only get warnings for redlight cameras, don't you thing that's strange that it's only redlights.
BAVC10
PostPosted: Sat Jun 12, 2010 2:25 pm    Post subject: Reply with quote
Hellfire
I guess the Redlight cameras show when no route is plotted as they are set to 0mph.
All my camera warnings worked perfectly today - have you got Sox.exe in your camera directory as you need this to get the .wav files working???
HellFire
PostPosted: Sat Jun 12, 2010 6:32 pm    Post subject: Reply with quote
I've got the sox.exe in C\Garmin folder, but never knew you had to have it in the camera folder to, did all your cameras work with no route plotted.
BAVC10
PostPosted: Sun Jun 13, 2010 10:08 pm    Post subject: Reply with quote
Hellfire
If I go to browse map I can see the PGPSW Speed Cameras - however, I don;t see ALL of them. Some seem to be hidden behind the map detail - wonder if this is due to the Icons being much smaller with the high resolution - I will try and download some of Gerry C's larger Icons for Tom Tom and see if that helps.
23.061 (04 Jun 25)
