Pocket GPS World :: View topic - TT 530
TT 530
tomcat76
PostPosted: Sun May 23, 2010 8:56 am    Post subject: TT 530 Reply with quote
Hi I have the TT 530 does the TT not have a full postcode search only the first 3 charaters?
I'm sure either this one or my original TT Go had it at one stage.
Regards Steve :-)
PostPosted: Sun May 23, 2010 9:11 am    Post subject: Reply with quote
Using Windows Explorer have a look at the folders/ files on the device, open the "zip" folder and there should be a Great_Britain postcode data file in it, if its not there you can download the file by following the link in Here - Mike
tomcat76
PostPosted: Sun May 23, 2010 9:38 am    Post subject: Reply with quote
Hi Mike that was a fast response, thank you....
I don't have a zip file on my TT
My map is 845.2645 believe that's up-to-date.
Found the file to download:-
Great_Britain.postal and
Great_BritianPostal.ver
Sussed it out, I needed a file called zip in my main TT directory, put the two files into that and I now have the full postcode search.
Thank's once again.
Regards Steve :-)
PostPosted: Sun May 23, 2010 9:51 am    Post subject: Reply with quote
You need to unzip the files to the "zip" folder on your device, if the "zip" folder is missing simply create this in the root directory of the device (Right click the drive letter associated with the device and select New/ Folder name the new folder "zip" (without the "") and then put the files you have downloaded in to the zip folder, you will then find your postcode options will work - Mike
23.061 (04 Jun 25)
