JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Sun May 16, 2010 4:03 am Post subject: Dimensions of n20/n30/n40/n50? |
Can anyone point me to details, e.g. on the TT web site, giving dimensions of the different models?
I'm looking for a case for a 940 and on this page Arkon give details of 2 hard cases both listed as suitable for "GO 520, 530, 720, 730, 930" but there is no mention of the 940 or 950. From memory, the 940 is not as deep as the previous models, but is the "face" the same size? If the case fits, but is too deep, I can pop in some foam, but I'd like a snug fit so that it doesn't rattle around.
If those cases wont suit, can someone recommend a good, cheap source for a 940 case? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
AliOnHols Pocket GPS Verifier
Posted: Sun May 16, 2010 4:52 am Post subject: |
Hi Jock, hope this helps - I have just measured my 730 with a ruler:-
119mm wide x 85mm high (77mm at edges) x 26mm deep (12mm at edges).
Ali. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Sun May 16, 2010 11:12 am Post subject: |
AliOnHols wrote: | Hi Jock, hope this helps - I have just measured my 730 with a ruler:-
Ali. | Ali,
Many thanks! Ruler time!!
ETA: Now, if I could find a ruler ... _________________ Jock
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Sun May 16, 2010 2:21 pm Post subject: |
I have a 940 and a 530 both with the TomTom original cases and they are not interchangeable. The 530 is thicker than the 940 case so it wont shut and the 940 is wider than the 530 so wont go in (it will if you really force it).
I looked at several case before I bought one for the 940 and I chose the TomTom one as it was a hard case with a sprung hinge (like an old spectacle case) and only just thicker than the unit itself. The 530 TomTom case is semi hard with a zip. _________________ Drivelux |
Posted: Sun May 16, 2010 3:48 pm Post subject: |
MrT wrote: | I have a 940 and a 530 both with the TomTom original cases and they are not interchangeable. The 530 is thicker than the 940 case so it wont shut and the 940 is wider than the 530 so wont go in (it will if you really force it).
I looked at several case before I bought one for the 940 and I chose the TomTom one as it was a hard case with a sprung hinge (like an old spectacle case) and only just thicker than the unit itself. The 530 TomTom case is semi hard with a zip. | Thanks MrT! Looks like I need a n40 specific case! Is this the one you have?
Does anyone know if the external dimensions of the n40 & n50 the same? _________________ Jock
Posted: Sun May 16, 2010 6:34 pm Post subject: |
x40 and x50 are identical in terms of external dimensions, only whats inside the 940 vs 950 is slightly different (the 950 contains a bit more free space internally than the 940 due to the missing FM Tx aerial) - Mike |
psyskiesman Lifetime Member
Joined: Jun 22, 2004 Posts: 322 Location: Swindon, Wiltshire
Posted: Sun May 16, 2010 6:56 pm Post subject: |
The n40 hard case is indeed very good, except for one thing. The interior is lined with a flock coated plastic which is very thin and very brittle; it cracks very easily and it is definitely not suitable for the hinge area which has broken up completely. I am trying to find a thin self adhesive rubber sheet to replace the interior of the case. |
Posted: Mon May 17, 2010 10:12 am Post subject: |
JockTamsonsBairn wrote: | Is this the one you have? |
Yes and the lining on mine has also split on the hinge but that does not yet cause me any problem. _________________ Drivelux |
Andy_P Pocket GPS Moderator
Posted: Mon May 17, 2010 10:36 am Post subject: |
I have always used soft cases intended for the Nintendo DS Lite portable games thingy for the wide-screen TomTom Gos in our household (x20,x40,x50).
Cheap and easily available.
The ones I try to get look like this:
and I get them from "Game" shops.
Although they often have an embroidered picture of Mario or Sonic on them, you can usually find a plain one.
Alternatively, for the One XL which has it's windscreen mount attached, I used a portable hard drive case, which is rigid and a bit deeper. They are widely available from PC World, Staples etc. |
Posted: Mon May 17, 2010 10:48 pm Post subject: |
Thanks, Andy. Now where's the Game Shop POI :-) _________________ Jock
Posted: Mon May 17, 2010 10:52 pm Post subject: |
JockTamsonsBairn wrote: | Thanks, Andy. Now where's the Game Shop POI :-) | There's a Game shop in Figueres! _________________ Garmin Nuvi 2599
DennisN Tired Old Man
Posted: Mon May 17, 2010 10:57 pm Post subject: |
JockTamsonsBairn wrote: | ETA: Now, if I could find a ruler ... |
Gordon Brown's available now. _________________ Dennis
Two of them are obesiting!! |
M8TJT The Other Tired Old Man
Posted: Tue May 18, 2010 7:51 am Post subject: |
DennisN wrote: | JockTamsonsBairn wrote: | ETA: Now, if I could find a ruler ... |
Gordon Brown's available now. | No, he isn't a ruler, he WAS a ruler, thank goodness |
Posted: Tue May 18, 2010 8:04 am Post subject: |
M8TJT wrote: | DennisN wrote: | JockTamsonsBairn wrote: | ETA: Now, if I could find a ruler ... |
Picky! It's a damn good job we had John Wayne and Errol Flynn - if we'd had to rely on you worrying about pedantry, we'd have lost the war. _________________ Dennis
Posted: Tue May 18, 2010 8:18 am Post subject: |
DennisN wrote: | Picky! It's a damn good job we had John Wayne and Errol Flynn - if we'd had to rely on you worrying about pedantry, we'd have lost the war. | You forgot Ronald Regan. Now he WAS really a leader, and he was elected as such as well. |
