barrowfordred Regular Visitor
Joined: 04/09/2003 21:03:05 Posts: 79 Location: Barrowford, Lancashire
Posted: Tue Jul 20, 2004 3:39 pm Post subject: Checkpoint woes |
I have an Ipaq 2215 with TomTom3. I have installed Checkpoint 2 un-installed & installed 3, but each version locks up on my machine. I activate Checkpoint & all is well. I can browse a menu, but only 1. The program then locks up and nothing else works. Only a soft reset will reactivate the Ipaq. This setup worked on my 3630 so why not now????
Also I noticed when I installed version 2 the menu list didn't have synchronisation in there??? |
swing Pocket GPS Verifier
Posted: Tue Jul 20, 2004 3:48 pm Post subject: Re: Checkpoint woes |
barrowfordred wrote: | Also I noticed when I installed version 2 the menu list didn't have synchronisation in there??? | Looking at the CheckPOInt website, synchronisation was a new feature for v3....
Steve |
Posted: Tue Jul 20, 2004 4:06 pm Post subject: |
So it was, yet the program worked OK on my 3630 with TomTom 2.
Not anymore. I installed version 2 to check if that worked. NO. |
Posted: Tue Jul 20, 2004 4:15 pm Post subject: |
Firstly, I think you need to make sure you are deleting all files if you are swapping between the two versions - v3 and v2 overlay settings files are not compatible, which might be causing v2 to not work after v3 was installed.
Secondly, only v3 is WM2003 compatible, so unless your 3630 was upgraded to WM2003, there is a lot of difference between your two PDAs which might be causing the problems.
However, I can't think of any generic reason why CheckPOInt would not work with a 2215, unless anyone can comment - I note there is reference elsewhere in this forum to needing to apply the latest ROM updates to the 2210 though. |
Posted: Tue Jul 20, 2004 4:20 pm Post subject: |
The problem is only on the 2215, the 3630 used a version of Checkpoint that had synchronise with it and was running ppc 2002. All was well. |
Posted: Tue Jul 20, 2004 9:32 pm Post subject: |
Well, I've tried everything now, or so it seems.
Start Checkpoint, OK, try the menu, OK, come out of menu, OK,
try another menu...nothing, try to exit nothing......
ppc 2003 rom version 1.00 |
Posted: Tue Jul 20, 2004 9:56 pm Post subject: |
Shame I can't edit...anyway.
Now I find that if I start TomTom and have overlays in the navigator map folder and images in the checkpoint folder (as advised on the checkpoint site) the images do not show up on the map. Only when I have BOTH the images and overlay in the map folder does it work. |
Posted: Wed Jul 21, 2004 9:34 am Post subject: |
barrowfordred wrote: | Shame I can't edit...anyway.
Now I find that if I start TomTom and have overlays in the navigator map folder and images in the checkpoint folder (as advised on the checkpoint site) the images do not show up on the map. Only when I have BOTH the images and overlay in the map folder does it work. | I think you need to have a copy of the image files in the CheckPOInt directory for the program to display the icons throughout its menus, and you will need the image for each overlay in the map directory for TomTom to be able to display the image on the map.
If you only want the image to appear within CheckPOInt, both in the menu and in it's little display window at the top of the Navigator screen, then the images are only needed in the CheckPOInt directory.
Steve |
