chippy24 Occasional Visitor
Posted: Sat Apr 03, 2010 11:08 pm Post subject: Icons onto Igo8 |
Hi Can you use bmp files as icons on IGO8 or do they have to be converted otherwise when you add new poi's all you get is google earth icon
thanks |
M8TJT The Other Tired Old Man
Posted: Sun Apr 04, 2010 7:03 am Post subject: |
I believe that you can use uncompressed .bmp files in iGO8. Ther is a iGO bmp compressor/uncompressor which works on most types of iGO compressed .bmps, but other than for space reasons, try using them uncompressed and nsee if they wory  |
Posted: Wed Apr 07, 2010 4:45 pm Post subject: Custom icons |
Hi tried just putting the bmp icons on but no joy in them showing up in the poi icon section. guess there is something else you have to do, seem to think that linkjet posted the know how as to how it is done but cant find it. There has to be a way to put your own icons on for specific poi's and not just have the google earth all the time |
linknet Frequent Visitor
Posted: Wed Apr 07, 2010 6:01 pm Post subject: Re: Custom icons |
chippy24 wrote: | Hi tried just putting the bmp icons on but no joy in them showing up in the poi icon section. guess there is something else you have to do, seem to think that linkjet posted the know how as to how it is done but cant find it. There has to be a way to put your own icons on for specific poi's and not just have the google earth all the time |
It's here, 10th item down on the page:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=67086
linknet |
Posted: Thu Apr 08, 2010 4:49 pm Post subject: icons |
hi Linkjet thanks for your quick reply I dont wish to sound thick doh! but where exactly do you put the ui_igo8, I know you say put into the root folder, but where is this, I've had a look on sd card but dont seem to be able to find it?
thanks |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Apr 08, 2010 10:26 pm Post subject: |
The ROOT of the SD Card is the Card itself before anything added, so just copy and paste the ui_igo8 folder straight on to the card i.e don't put it inside any other folder which is already there.
Once added you should see the 2577 Folder, the iGO8 folder, a backup folder and maybe a device .nng file and the ui_igo8 folder on the card. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Thu Apr 08, 2010 10:37 pm Post subject: Re: icons |
chippy24 wrote: | hi Linkjet thanks for your quick reply I dont wish to sound thick doh! but where exactly do you put the ui_igo8, I know you say put into the root folder, but where is this, I've had a look on sd card but dont seem to be able to find it?
thanks |
The root folder of any partition is the "highest" folder in the hierarchy. The root folder contains all other folders and can also contain files.
But what I actually said was "Unzip the ui_igo8 folder and copy it to the iGO8 root folder on the SD card giving 'iGO8\ui_igo8'."
Meaning the ROOT of the iGO8 folder not the ROOT of the SD Card so you finish up with 'iGO8\ui_igo8'
linknet |
Posted: Thu Apr 08, 2010 11:03 pm Post subject: |
What's in this ui_igo8 folder then??? I ain't got one What am I missing out on  |
Posted: Thu Apr 08, 2010 11:19 pm Post subject: |
M8TJT wrote: | What's in this ui_igo8 folder then??? |
More icons.
M8TJT wrote: | I ain't got one What am I missing out on |
Yes you have, look inside your data.zip.
linknet |
Posted: Fri Apr 09, 2010 8:18 am Post subject: |
linknet wrote: | Yes you have, look inside your data.zip. | I knew that I had one there but thought perhaps I was missing out on something not having one in \iGO8  |
Posted: Fri Apr 09, 2010 10:24 am Post subject: |
M8TJT wrote: | linknet wrote: | Yes you have, look inside your data.zip. | I knew that I had one there but thought perhaps I was missing out on something not having one in \iGO8  |
You can do that with any of the folders within the data.zip, iGO8 will use any files in the unzipped folders in preference to those in the data.zip.
linknet |
Posted: Fri Apr 09, 2010 11:10 am Post subject: |
Ah, I see . I didn't realise that  |
Posted: Sat Apr 10, 2010 10:24 am Post subject: icons igo8/ui_igo8 |
Hi thanks for that Linknet think I've got it now, do I presume right that you then put your own Poi's and icons into this ui_igo8 folder instead of the one on igo? |
Posted: Sat Apr 10, 2010 10:37 am Post subject: Re: icons igo8/ui_igo8 |
chippy24 wrote: | Hi thanks for that Linknet think I've got it now, do I presume right that you then put your own Poi's and icons into this ui_igo8 folder instead of the one on igo? |
No, you need to read my original post, it gives full instructions on exactly what to do.
linknet |
Posted: Sat Apr 10, 2010 11:07 am Post subject: ui_igo8 |
Hi just tried putting the new ui_igo8 onto the sd card but it came as this file already exists do you wish to replace it? do I do this ? or is there something Ive done wrong |
