Graeme2812 Frequent Visitor
Joined: Mar 14, 2004 Posts: 297 Location: Dundee, Scotland UK
Posted: Mon Apr 05, 2010 7:19 pm Post subject: Disable Auto Shutdown via USB/PC? |
Is it possible to dissable the auto power down process that my 550 has when it is connected to my PC?
The reason I ask is that I have a USB port in my car and it will be much more convient and tidy if i can plug my TomTom in via the USB port rather than the Aux socket. I have tried plugging the device in on the car's USB port and it continues to power (well, power LED lights up) but it automaticly shuts down everytime after a few min.
Can't see anything in the device settings, does anyone have any ideas?
Thanks,
Graeme _________________ Graeme Bennett
Go 540 LIVE
App. 9.510.1234792.1 (2039,04/04/2013)
United Kingdom & ROI v945.6174 |
Posted: Mon Apr 05, 2010 8:03 pm Post subject: |
Use Notepad to create a new file with just a "1" in it (without the "") save the file as "noautosuspend.dat" then copy it straight to the device (no "" in the file name), drop the file straight on to the drive letter associated with your device using Windows Explorer - Mike |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon Apr 05, 2010 8:50 pm Post subject: |
Well !!, thanks for that Mike.
Been something that's been bugging me as well, but never thought to ask
Thought it was a 'given' so to speak.
Will it work with my TT720??
Cheers Bob _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Mon Apr 05, 2010 9:17 pm Post subject: |
253 wrote: | Will it work with my TT720?? |
Bob, it works fine on a 720 as thats the device I first started using this "fix" on - Mike |
AliOnHols Pocket GPS Verifier
Posted: Tue Apr 06, 2010 9:58 am Post subject: |
think we need to change your name to MikeTheHero! This has been bugging me for the last year also, but not any more. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Tue Apr 06, 2010 10:14 am Post subject: |
Mike
Many thanks indeed for this tip
John _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
Posted: Tue Apr 06, 2010 8:03 pm Post subject: |
Thanks verymuch again Mike.
Works a treat. _________________ Graeme Bennett
Go 540 LIVE
Posted: Fri Apr 09, 2010 1:20 pm Post subject: |
I know this is the wrong title ,but here goes:-
Is there a similar software instruction to turn the Go720 on when power is connected via the usb connector? _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Fri Apr 09, 2010 4:47 pm Post subject: |
jonial wrote: | Is there a similar software instruction to turn the Go720 on when power is connected via the usb connector? |
The Go-x10 devices certainly did this but due to issues with the mount TomTom removed the auto power on/ off and despite many requests to reinstate this functionality on the newer products they don't listen - Nobody has found a hack/ work around to enable it either so I am afraid you are stuck with it - Mike |
Posted: Fri Apr 09, 2010 5:20 pm Post subject: |
Hi Mike
Thanks for the answer, which was as I expected.
I did have a G0710 and I can't now remember quite how it was done but you could get the Go to turn on and off with the ignition which was very useful. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Fri Apr 09, 2010 5:46 pm Post subject: |
With a 710 you would need a Navcore release prior to 6,51 to get the auto on/ off working again, once 6,51 was rolled out which was needed for the FM Transmitter mount and RDS-TMC receiver support the auto on feature disapeared and hasn't been seen since! (I do still have a couple of 910 Navcores on this PC that are pre 6,51 but no 910 to run it on as it burnt out) - Mike |
Oldboy Pocket GPS Moderator
Posted: Fri Apr 09, 2010 6:17 pm Post subject: |
The latest 910 software still supports the auto on/off function on the standard mount. (v7.903). _________________ Richard
