Pocket GPS World :: View topic - British Summer Time - Don't forget to update your profile
Anita
PostPosted: Sun Mar 28, 2010 11:48 am    Post subject: British Summer Time - Don't forget to update your profile Reply with quote
Unless I've missed it (which is quite possible, and if so I apologise) Darren seems to have forgotten this time, so I'll do it for him!
As we've moved to British Summer Time (GMT+1) this morning our UK readers will all need to change the timezone setting in their profile to BST to ensure their posts and those of others display the correct time.
The setting can be found in your profile accessed from the link at the top of the forums. In your profile, scroll towards the bottom where you will find the the preferences section and change the Timezone from GMT to GMT+1. If you are not in the UK then you should ensure you are using the correct time offset (+ or -) as necessary.
Unfortunately this has to done manually by every user when the clocks change but it is a simple process. When the clocks go back in the Autumn the process should be reversed.
If you do forget then posts will appear to have been posted an hour earlier so please do make the change.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
22.062 (12 Jun 24)
