Pocket GPS World :: View topic - Port Locking with TT2
androidgb
PostPosted: Mon Jul 19, 2004 9:59 am    Post subject: Port Locking with TT2 Reply with quote
I've read in another thread that in order to have Memory Map and TomTom running it is necessary to remove TomTom~GPS.
I have done this on the PPC using the remove programs function, but now when trying to use TomTOM I see GPS disabled.
This is exactly the same as the other user in the thread "TomTom3 and Hiking"
Memory Map works fine.
Any ideas?
Andrew
PostPosted: Mon Jul 19, 2004 3:15 pm    Post subject: Reply with quote
completely uninstall the TomTom GPS driver (both instances) and then, after a soft reset, install TomTom GPS 2.07 (from this site's download section)
androidgb
PostPosted: Mon Jul 19, 2004 5:30 pm    Post subject: Reply with quote
Thanks for the info.
Can you explain what you mean by both instances ?
Many thanks
PostPosted: Mon Jul 19, 2004 5:51 pm    Post subject: Reply with quote
It may be listed twice in the "installed programs" list
TomTom GPS
TomTom ~ GPS
androidgb
PostPosted: Mon Jul 19, 2004 10:35 pm    Post subject: Reply with quote
No mention in the installed list, but still getting the GPS disabled message
Confused
PostPosted: Mon Jul 19, 2004 10:39 pm    Post subject: Reply with quote
have you done a soft reset, installed GPS 2.07, and done another soft reset?
androidgb
PostPosted: Mon Jul 19, 2004 10:54 pm    Post subject: Reply with quote
Looks promising, I'll try it in the car tomorrow.
Many thanks
Just one other thing , what will happen if I upgrade to TT3 ?
Andrew
androidgb
PostPosted: Tue Jul 20, 2004 11:44 am    Post subject: Reply with quote
OK done that, can either have Memory Map or TT2 running correctly but not at the same time. If I have either running, when trying to run the other program I get "Can't open Com Port 1"
Any ideas
nej
PostPosted: Tue Jul 20, 2004 11:57 am    Post subject: Reply with quote
This is normal behaviour. When TomTom opens it opens COM1 in order to read the incoming data. If TomTom has it open then MemoryMap won't be able to use it and vice versa.
There is some software around somewhere that will allow to accept the data on COM1 and it will then squirt it out on port 2 and 3, for example, so you can configure TomTom for COM2 and MemoryMap for COM3 and it would work. It's a kind of software re-radiating antennae using virtual COM ports. I've no idea what it's called though, but I'm sure someone else will!
PostPosted: Tue Jul 20, 2004 5:55 pm    Post subject: Reply with quote
yep... http://franson.biz/GpsGate/
When you move to TomTom 3 there is no need to change the GPS driver. But if you do, make sure you use GPS 3.03 - that one is cooperating again.
androidgb
PostPosted: Wed Jul 21, 2004 8:41 am    Post subject: Reply with quote
Thanks for all your help guys.
OK, I can only use 1 application at a time, without additional software, but if I uninstal TomTom GPS, to allow me to use MemoryMap can I still use TomTom.
MR T suggests I can in this http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=9360
I tried it but got GPS disabled
MrT
PostPosted: Wed Jul 21, 2004 8:51 am    Post subject: Reply with quote
Once you have installed the TomTom GPS and it works. You uninstall the "TomTom~GPS" from remove programs on the PocketPC (not your main PC). This does not actually uninstall TomTom GPS and it should still work.
This is what I have done and I can use both TomTom and MemoryMap but not at the same time.
