Pocket GPS World :: View topic - Map udates - are they worth it ..?
Goto page Previous  1, 2, 3, 4
dhn
PostPosted: Thu Mar 18, 2010 12:12 pm    Post subject: Reply with quote
I can't see any map version info on the Routes web-site so I'd be wary of assuming it uses the latest data?
I have been told (for NA, anyway) that route planner is one version behind actual. If that is the case, I presume it's at 840 for NA now.
joaocb40
PostPosted: Fri Mar 19, 2010 10:01 am    Post subject: Reply with quote
No, it is not the latest map.
PostPosted: Fri Mar 19, 2010 8:05 pm    Post subject: Reply with quote
AFAIK, the Routes web-site is currently on v840 for the UK and Europe too.
falkirk81
PostPosted: Fri Mar 19, 2010 8:39 pm    Post subject: Reply with quote
Andy is correct. All you need to do is look at the Northbound carriageway of the Forth Road bridge in Edinburgh. It should NOT be a toll road, and up till and including v8.40 maps, it has been marked as a toll road.
v8.45 map data now has this correct.
So when you see the toll charge part of that bridge removed, then it will be the latest map data Smile
Same principal applies to the Tay bridge in Dundee, the SB carriageway should NOT be a toll road. v8.45 map data has this correct too!
Steven
Tomtom GO 1005 LIVE
iPhone 12
PostPosted: Fri Mar 19, 2010 8:46 pm    Post subject: Reply with quote
Shows what a gullible old man I am - if TomTom offer me something, I'll believe it. Joker
tonygold
PostPosted: Thu Mar 25, 2010 9:32 am    Post subject: Reply with quote
mikealder wrote:
jimbo_hippo wrote:
My postcodes are missing. Not so much a map update issue, it was left from a recent wipe but after 6 years of Brits complaining about this it's still not fixed.
If you click Here you will download the latest PostCode data for your device, just unzip the download to the device - Mike
hi
what folder do you paste this info into please, is it the same folder as the pgpsw speed cams are in? also would this info be more up to date than the info on my 1 year old tomtom one IQ routes has built in? and if so will it simply overwrite the older data.
many thanks.
Robin2
PostPosted: Thu Mar 25, 2010 9:49 am    Post subject: Reply with quote
No, you don't go into the map folder. In the root of your device you should see a folder called Zip. This should contain 4 files, 2 for UK and 2 for Netherlands. You just unzip the new postcode files into this folder - it should overwrite the old ones (you will be asked first). Don't forget to back up the old Zip folder onto your desktop first, in case the new one is corrupted for some reason
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
tonygold
PostPosted: Thu Mar 25, 2010 9:57 am    Post subject: Reply with quote
Robin
thanks robin.
i will do that now. would this new zip file be more up to date than a year old one in your ooinion?
Robin2
PostPosted: Thu Mar 25, 2010 11:43 am    Post subject: Reply with quote
It's the very latest, 845. I just checked my own device, which I updated fairly recently, and that's 801, so I'm going to update mine, too Smile
Robin
Satmap Active 10
PostPosted: Thu Mar 25, 2010 8:45 pm    Post subject: Reply with quote
In the zip folder, double click the Great_BritainPostal.ver and open it with Notepad - it'll say the version number.
tonygold
PostPosted: Fri Mar 26, 2010 8:08 am    Post subject: Reply with quote
thanks for info dennis
Page 4 of 4
