Pocket GPS World :: View topic - 940 keeps rebooting
940 keeps rebooting
111rdw
PostPosted: Fri Mar 05, 2010 11:35 am    Post subject: 940 keeps rebooting Reply with quote
Hi all,
My 940 was rebooting randomly every 2-3 days. To be honest it's never been very stable. Every upgrade ususally causes a few freezes requiring some interverntion to sort it out. Following advice from tomtom I have reloaded everything. Now it reboots everytime I turn it on. The latest advice from tomtom is that I need to move my documents from drive d to c!!!! I have done a trawl through the forum and it seems this problem is not curable. Do I try to get it repaired or does anyone have some better advice?
MARViN2003
PostPosted: Fri Mar 05, 2010 12:14 pm    Post subject: Reply with quote
My 520 would reboot just after switching on and then be ok until I turned it off / on the next time.
In the end I cured it by doing a chkdsk and a defrag of the internal tomtom drive and the memory card I was using.
It's been fine since (but I regularly do a quick defrag of it just in case).
PaulB2005
PostPosted: Fri Mar 05, 2010 12:54 pm    Post subject: Reply with quote
Check in the Map Folder for a file called mapsettings.cfg. If it is there delete it (or move it to the PC) and reboot. See if that works. The TomTom will regenerate the file but you'll loose any user settings.
Does it have a proper hard drive or solid state (flash) drive?
111rdw
PostPosted: Fri Mar 05, 2010 1:10 pm    Post subject: Reply with quote
Both of your suggested actions were part of the input from tomtom as part of fixing my original issues. I can try both again to see if it will clear this latest issue. Has anyone actually cured this?
PaulB2005
PostPosted: Fri Mar 05, 2010 1:15 pm    Post subject: Reply with quote
Do NOT Defrag solid state drives or SD Cards. There is no point as they don't work in the same manner as proper hard drives with spinning platters.
ChkDsk is ok but defragging solid state media like SD cards and USB thumb drives will reduce their useful life much quicker than standard useage.
PaulB2005
PostPosted: Fri Mar 05, 2010 1:18 pm    Post subject: Reply with quote
Removing the mapsettings.cfg file usually cures the rebooting issues...
Have you tried ClearFlash or a reset? See AndyVaughans 5 fixes here
111rdw
PostPosted: Fri Mar 05, 2010 1:27 pm    Post subject: Reply with quote
Will try the 5 fixes. However it was a backup and restore which got me to where I am now.
PaulB2005
PostPosted: Fri Mar 05, 2010 1:33 pm    Post subject: Reply with quote
Well i did just mean the delete mapsettings.cfg, ClearFlash and reset.
111rdw
PostPosted: Fri Mar 05, 2010 1:48 pm    Post subject: Reply with quote
OK. I'm will try anything to get this sorted or it's off to ebay or the bin
D4VE
PostPosted: Fri Mar 05, 2010 7:25 pm    Post subject: Reply with quote
One fix I find that works more often than not is to "Operate My Go" in TomTom Home. Then add or edit a favourite exit properly. Works for me
iPhone4 IOS 4.3.3
TomTom Western Europe v865.3252
App 8.300 V1.6 (670441)
TomTom iPhone Car Kit
PC Operating System: Windows 7
blackstars
PostPosted: Sun Mar 07, 2010 10:33 pm    Post subject: Reply with quote
my 940 keeps doing it, works fine other than the rebooting issue, i just ignore it ! or is it a sign of unrepairble trooooble looming ?
jez6363
PostPosted: Wed Jun 06, 2012 12:04 am    Post subject: Reply with quote
I just hit this, while on a driving holiday in France - needless to say, most frustrating.
It appears to be because the internal TomTom drive / flash gets corrupt somehow. In my case I was just following a route, and then it read out some instructions in dalek speak (it was maxing out its processor so couldn't synthesise speech right), and then it crashed, and went into an endless series of reboots. I tried all the usual things, but nothing helped.
I fixed it in the end by:
1. Connect to computer and backup everything off the TomTom
2. Format the drive - as FAT32, NOT quick format
3. Use TomTom Home and let it re-install everything except the map (took two updates for the application). Note you have to explicitly download the computer voices in TTH, by going to the Voices part and choosing the computer voices, if you want them.
4. Copied back the map from backup (it is huge to download, and in my case the map was not corrupt)
5. Set all my preferences and favorites up again
Note - in case you didn't know, you should save all your favorites into a new POI, so that when (not if, when) TT lose all your favorites, you can easily set them up again, by Add Favorite, and choosing each POI in turn.
Basically TT suck really badly, and are gradually going downhill. NEVER buy a TomTom again - they are going from bad to worse to absolutely dreadful.
PostPosted: Wed Jun 06, 2012 12:30 am    Post subject: Reply with quote
The re-booting COULD be down to the internal memory beginning to fail.
It might be worth trying copying EVERYTHING (i.e. the Navcore system files too) onto an SD card and letting the unit boot from there instead (it will do so automatically if it sees the system files on the SD), but probably safest to delete everything from the internal just to make sure it doesn't try to access anything from there.
"Settling in nicely" ;-)
PostPosted: Wed Jun 06, 2012 9:01 am    Post subject: Reply with quote
I think that Ebay is the way to go. Sell it to some unsuspecting patsy and let them sort it out. Rolling Eyes
PostPosted: Wed Jun 06, 2012 4:42 pm    Post subject: Reply with quote
@M8TJT.... You shouldn't jump to conclusions. How do you know that 111rdw isn't going to describe it exactly as it is?
