Pocket GPS World :: View topic - Splash screen
Splash screen
flyingrigger
PostPosted: Thu Jan 14, 2010 1:54 pm    Post subject: Splash screen Reply with quote
Having some problem setting up a "custom" splash screen on my new XL IQ Routes! On my "one" It was just a matter of importing the "new" bmp and putting a "1" in the old bmp (in front of the .bmp) Have tried this with the XL and it 's not using the new splash! I've obviously got something wrong!!! HELP!! Dave.
dhn
PostPosted: Thu Jan 14, 2010 2:08 pm    Post subject: Reply with quote
It may be an issue where your 'one' model had a 3.5" screen and so the splash.bmp file worked.
For a 4.3" model, you need a file called splashw.bmp but it's not as simple as just renaming a sphlash file to splashw. The file has to be the right size.
Try this:
Go here and upload the image in question and select a 720 unit as the model you have (4.3") screen. It'll create the proper sized file for you and you simply download.
Stampy72
PostPosted: Thu Jan 14, 2010 2:11 pm    Post subject: Reply with quote
Try this link ==============> HERE
Worked fine on my IQ XL
XL LIVE IQ Routes (Europe)
App 9.465.1074274.2
OS 842337 (2025, 27/9/2012)
GPS v1.20, Boot 5.5138
Map : "Europe_North" v 900.4602
Fibre
PostPosted: Thu Feb 25, 2010 12:14 pm    Post subject: Reply with quote
where do you put the file -- in the map??
or??
Happy to meet -- Sorry to part -- Happy to meet again
PostPosted: Thu Feb 25, 2010 12:35 pm    Post subject: Reply with quote
splash.bmp, antitheft.bmp, suspend.bmp (or their "w" variants for widescreen models) all go in the root directory, i.e. not in any folder.
More info on root directory if needed: What Is This "root Directory" I Keep Hearing About?
Not all models support the 'suspend' image. Those that do will use it if you DON'T have "Warn not to leave device in car" selected, otherwise the 'antitheft' image is shown.
For models that don't support 'suspend', you can just replace the default 'antitheft' image with one of your own.
If your model does support the use of a 'suspend' image, did you know you can also have a 'suspend.ogg'? i.e. A SHUTDOWN SOUND.
PostPosted: Thu Feb 25, 2010 12:37 pm    Post subject: Reply with quote
or??
In the root of the device, not in any folder (browse with Windows Explorer and you'll see the existing splash.bmp or splashw.bmp there).
Fibre
PostPosted: Thu Feb 25, 2010 1:32 pm    Post subject: Reply with quote
thank you -- it was missing after doing a map up grade..
but I found an old copy in a backup file and cut and pasted -- working fine..
Thankyou..
OH yes -- forgot to say that I have just bought a new 750L..
seems to be good apart from the map download
Maurice
Wendolene
PostPosted: Fri Apr 02, 2010 11:45 pm    Post subject: Reply with quote
Just wanted to say thank you for the info here. I was just about to ask the same question when a search pulled in this answer.
Great link.
Cheers.
Cracking Toast Gromit!
TomTom Go Live 750
App: v9.510.1234792.103
Map: Europe v1005.8763
All installed on a 4GB Class 6 microSD Card.
