Joogy Occasional Visitor
Posted: Sun Jan 31, 2010 8:11 pm Post subject: Telmap 5-Help!! |
I downloaded version 5 this week onto my Blackberry 9700 but seem to be having a problem with my search function.
When I put in a street name it says its searching for ages and then I get the following message:
"Unable to connect to network. If problem persists,please check network settings or contact customer support"
I can access the internet via my browser no problem so cannot understand why I'm getting this message.
Maybe I'm being a bit thick here but could it be because I'm conducting the search indoors and you need to be outside?
Also whilst I'm here, i did prefer the older 4.5 version so is there anyway i can get that back?
Joogy |
SyBorg Regular Visitor
Posted: Sun Jan 31, 2010 8:39 pm Post subject: |
Did you choose the right version BIS or BES?
As to going back to 4.5 I expect the answer is no. Clearly the point of the TUG is to get feedback on beta versions - giving away the previous version would be of no benefit to Telmap. |
Posted: Sun Jan 31, 2010 11:33 pm Post subject: |
SyBorg wrote: | Did you choose the right version BIS or BES?
Hello Syborg,
Thanks for replying. Do you know what, I'm not even sure what version I chose!
Is there any way I can tell? If not is it best to delete it and then download it again and if so what version?
Thanks for your time and help.
Joogy |
Posted: Mon Feb 01, 2010 10:01 am Post subject: |
I don't know of a way to check for BES/ BIS in the application.
In your situation I would confirm which I needed (normally BES if a work BB, BIS if personal but always the case), remove the current install and try again. |
Posted: Mon Feb 01, 2010 11:33 pm Post subject: |
SyBorg wrote: | I don't know of a way to check for BES/ BIS in the application.
Thanks Syborg. I have downloaded it again and it seems to search now and come up with addresses but only if I type in post codes and not street names! I take it for directions I would need to be outside?
Also on another forum someone said you can still get the 4.5 version by using this link
http://downloads.telmap.com/tug/inst...gator_full.jad
However I can't get it to work when I put the address on my blackberry!
Which is no surprise as I can just about switch my phone on!
Joogy |
TUGAdmin Frequent Visitor
Posted: Wed Feb 03, 2010 10:08 am Post subject: Your problem running Telmap5 |
Hi joogy,
I hope you have it sorted out.
In general - BES means that your BB is connected to your corporate email account through a server managed and maintained by your corporate IT department.
BIS means that you just bought your BB from your mobile provider.
But there are more accurate and technical ways to check how your BB is actually configured.
If you continue to have problems please contact us directly at TUGAdmin_at_telmap_dot_com and we will run it through our support department.
TUGAdmin |
